Topic: Turbo coupe spring hight (Read 21473 times) previous topic - next topic
Reply #60
Quote from: Aerocoupe;427863
To clarify, the SN95 struts are about 1" longer in their compressed height. Other than that there is not much physical difference. If your car is stock height or mildly lowered the SN95 struts are what you want to go with. If your car has more than a mild drop say 2"+ then go with the Fox struts.
The rear shocks are different in the fact that the SN95 units have internal bump stops and the Fox units do not. This is why they are typically used with coil overs.
Darren
This is great info didnt know the SN95s had internal bumpstops. My Bird isnt slammed but its around 1 1/2 maybe 3/4 drop.
88 Turbo Coupe 5 Speed..Full exhaust, K and N, Boost Controller
Reply #61
I just want to get the front of mine down a little more to match the rear.
Its currently bottoming out the struts.
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
Reply #62
How the hell do you not have a big hole sed into the gas tank? LOL
Reply #63
Air bags :)
95 Falcon GLi
Reply #64
Quote from: EFFalcon;428011
That is sick
Once you get the front end down, it'll look REALLY good
Reply #65
Quote from: Aerocoupe;427862
From Chuck W...you know the guy that started this site. In all seriousness Chuck W makes and sells them.
Darren
Im pretty newish here...does Chuck W have a site or store on here?
Reply #66
I know you are new to the site but the search function is your friend.  Search for Chuck W in any thread, click on his user name, and then click on "Visit Webpage".
http://www.turbochuck.com/
Darren
Reply #67
Darren
Looks like I may have to do up a GB on some adapters.
:hick: Also, This isn't my website. ;)
Reply #68
Chuck you still selling those rear shock adapters? Didn't see them on the website..
Reply #69
Quote from: Chuck W;430342
Quote from: ianb;430345
They never were.
I'm undecided on doing more. I hate welding them up, and I hate sitting on them for over a year after I weld them up.
IF I do any more, it'll be in a group buy format.
Reply #70
I'm trying to decide between chuck mounts and a motor plate right now on the tbird
