Topic: 5.0 SO. More power? (Read 3499 times) previous topic - next topic
5.0 SO. More power?
Hey guys. I was just wondering if there is anything I can do to get some more power out of my 86 Cougars standard output 5.0. What would you do to get more power out of one?
5.0 SO. More power?
Ford Explorer upper and lower intake and a larger throttle body plus an HO speed density computer +19 pound injectors
Get An ho camshaft as well
BBK unequally exhaust headers and straight duel exhaust
Lincoln Mark seven fuel pump which is about 45% more gallons per hour than stock
A set of GT 40 heads off of a Ford Explorer as well
You could scroll through my engine build in engine tech and see what parts I put on my car but we are still working out a few bugs
5.0 SO. More power?
H.O upper intake (87-93 Fox Mustang), remove air box silencer, underdrive pullies, phenolic spacer, advance timing a little, fresh tuneup.  All this can be done to the stock motor you have without changing the computer, injectors, heads, etc.
5.0 SO. More power?
I have a good GT40 UPPER AND LOWER for cheap if someone is interested!!
5.0 SO. More power?
A GT-40, or Explorer? If it's a GT-40, PM me Tom.
5.0 SO. More power?
Quote from: TOM Renzo;421279
ill get in line as well
5.0 SO. More power?
The only worthwhile thing to do with an SO is to either swap it, of take the thing apart and make it into an HO (Cam, PCM, Heads, Upper and Lower Intake, Injectors, and Throttle Body) We all like the GT40 heads and the GT40/Explorer intake as a starting point for this.  Add headers and a good dual exhaust and you're taking about 265 to 280 HP.  Any 'little' mods like timing or under-drives are only going to net around 5 HP if that.  You won't notice that on an SO, and if you do, it's all in your head.  You WILL notice a difference from a timing bump on an HO.  Personally, I would avoid under-drive's as they don't make power, they reduce losses and they slow down things you don't want to slow down such as your (already barely adequate) alternator and your water pump.
5.0 SO. More power?
Quote from: TheFoeYouKnow;421289
exactly,  i wondered why people reduce thier drive pully sizes knowing things would be slower... seems not worth it.
5.0 SO. More power?
Quote from: jcassity;421294
With a 3g alternator and a high volume water pump this may be less of an issue, but I just can't imagine a reason why I'd want to slow them down.  I've made 1/4 mile passes where I've gotten a tenth and a half by running with the 3-pin alternator connector disconnected, but on the street, I'll sacrifice a couple horses to know I've got enough current and enough coolant flow.
5.0 SO. More power?
If it looks like this I'm interested.
5.0 SO. More power?
Quote from: thunderjet302;421300
If it looks like that.............. we are all interested. LOL
Mike
5.0 SO. More power?
Quote from: mcb82gt;421302
Not me! :hick:
5.0 SO. More power?
Explorer intakes (being all cast aluminum) can be opened up bigger.  In stock form, they're within 5% or less of the Cobra/FRPP GT40 intakes, much more plentiful, and much less expensive.  The tubular GT40 intakes are prettier, though.
5.0 SO. More power?
Here's the lowdown on all 3. FRPP GT40, Exploder, and Cobra
http://www.andersonfordmotorsport.com/dmdocuments/media/intake.htm
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
5.0 SO. More power?
