Topic: 5.0 SO. More power? (Read 3468 times) previous topic - next topic
5.0 SO. More power?
Actually, thats a 98-01 intake. No egr hole in the lower, as the p-code motors used an external egr setup. The upper will have no egr hole as well, and actually have a gap in the center of the lower , as evidenced by the marks on the gasket. Late 97's used external egr, but still had the older intake set.
Same style intake set I'm using on my car, works great if you don't want to retain EGR.
I learned some of this the hard way on my first 5.0 build in my ranger. I left the late 97 lower on the motor i used, and put a 99 upper on it. The lower had the egr hole (even though the motor was external egr), and the upper just had a gap in the casting there. Took me quite awhile to figgure out where the exhaust leak noise was coming from and why it was happening.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
5.0 SO. More power?
Just cleaning up before the winter. I have a lot of stuff to sort through. When JR was young he accumilated a bunch of HI POWER amps and huge speakers. I put some of them on the counter and they sold in an HOUR. I am glad JR is over the THUMPING RADIO THING. That used to burn my ass. I just found 2 more amps in the basp00get of the shop tonight. Will put them out tomorrow and see what gives.
5.0 SO. More power?
I thought I was limited cam and head wise because of the flat top pistons that the 86 5.0s had. Will I be able to use a H.O cam and GT 40 heads?
5.0 SO. More power?
you could always flycut your pistons if they don't fit. a few guys on here have gt40's and an ecam on a stock short block.
5.0 SO. More power?
Measure twice dont crash ONCE!!
