Topic: Fuel pressure question.... (Read 5164 times) previous topic - next topic
O.K., I mildly looked for a thread on this, and didn't see one. What is the recommended fuel pressure at idle, and setting (5.0 SEFI, 24# injectors...info in my sig). Where should I set the AFPR and so on? Thanks.
around 40 41 with the vacuum disconnected is a good start
Thanks. I'll install the AFPR asap and set it where I need it. I THINK it was set to 42 with my 19# injectors. I'll keep it at the stock numbers for the 24's.
when I ran 24's I bumped it a little higher .......... but all I want to do is go fast lol
Fast is fine, but I don't want it to be running too rich. What should the gauge show with the vacuum line hooked up after it's set with the hose off?
rated flow is 43.5 psi, but I believe the computer expects 40 psi.
Around 35
With the current FPR it was reading about 22 at idle with the vacuum hose hooked up.
to low set it to 33 ish
what pump do you have
Haystacks is correct most all injectors are rated at 43.5 PSI for  flow at rated output. And an injector should never be operated past 80% DC. I would set the regulator at or around 44 LBS NO VACUUM. 22 lbs is ABSOLUTELY NG even for a stock setup. Better find out why your fuel pressure is so low before jumping in to new injectors or a regulator. Your car must run terrible if this is the fuel pressure you are running. And you could very well have leaned the motor out drastically. Better check that out real fast. Good luck
It has a 255lph pump. I have been wondering if it's pumping the fuel that it should be. I have had 24# injectors on the car for some time, and was running my Kirban adjustable fuel pressure regulator. When we were installing new rings and bearings, and had everything apart, I misplaced my Kirban and installed a factory FPR that I had in my desk drawer in the garage. I have since found the Kirban, but haven't installed it yet.
So, should I install the Kirban, check the pressure and go from there?
put it on and see what happens if you try to crank the pressure and it wont go you probably have a week pump or clogged filter
I'll get after it tomorrow. I'll start with the FPR, then, if necessary, the filter and if I have to, I'll order a pump. I appreciate you guys. If there are any more comments, or lessons, or whatever, keep it coming.
you can check to see if the stock regulator is bad if there is any fuel in the vacuum line
No fuel in the vacuum line. I've had that off a short time ago when I was swapping the valve covers and had removed the upper intake.
