Topic: New springs and shocks (Read 4300 times) previous topic - next topic
My car is in need of new shocks and I'd like to get new springs along with it. Does anybody know what are the stiffest shocks made for Tbirds? Also what are the dimensions of turbocoupe springs. I'd like to get a higher spring rate but I don't even know what the stock spring rate is.
Thank you for your help.
If I recall the conversation I had with Jack Hidley at MM correctly, you are stuck with the stock springs and rates unless you want to lower the car and go with SN95 springs and shocks.
Unless you man up and get coil overs...kidding, no really.
Darren
If you don't mind lowering significantly, the setup i run is very stiff and handles well with all junkyard/forums/ebay parts, other than the control arms.
Front:
03-04 cobra struts and springs
Rear:
Bullet/Mach1 springs and shocks, with ChuckW adapters, and CHE adjustable arms.
I have poly bushings everywhere, and it has a very firm ride, corners wonderfully.
I'm not sure how much it would lower a TC, as mine is either a base or a lx.
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Cut a coil off your stock springs!!!
How much will the mustang springs lower it down?
Before....factory Sport springs....
After....SN-95 springs.....
About a 2 inch drop all around. Nice factory feeling ride, and still able to clear a speed bump.
Oh wow that looks great! So are SN95 shocks and springs just a bolt on replacement?
Actually, I still have the struts that came with the Bird (I have new '86 T-Bird struts ready to go on), and Thunderbird air shocks out back, filled to 30 psi. I'm getting a set of Chuck's Mustng shock mounts for the rear, and may look into the best shock at that time, but for now, I'm pretty happy with it.
the sn springs look good
I wanted the Sport lower than stock, but in a realistic manner. I need to be able to take a speed bump, or "real" roads without having to come to a near stop and crawling over bumps. Screw that.
yea ive slammed a few stangs and crawling over bumps gets old lol
True, and to add to the reasons I like these springs, The car rides like it should. No bouncing around or a rigid ride. Comfortable, and functional.
I need to get a set
They are all over Ebay.
