Topic: New springs and shocks (Read 3974 times) previous topic - next topic
It also says "make an offer"....
http://www.ebay.com/itm/99-04-OEM-Ford-Mustang-GT-Suspension-Coil-Springs-/130944735453?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7cea18dd&vxp=mtr
From a lot of the listings I've seen on Ebay, and the cost of shipping in general, make them an offer. That price seems better than most as it is, but apparently he's ready to take less.
whats not on ebay lol
good find it would cost close to that out of the yards around me
Offer $70 and work your way up if you have to.
I need to get a few things for the bird before I lower it .....wish I could right now lol
Simple question!!! What is the spring rate load height and wire diameter. What is it,s rate at load height. What is it's effective numbers of coils? What is it's spring rate deflection at 1" load rating.  Springs are a science and all the numbers need to be evaluated. Not just the ride height. Just me!!
Reducing effective coils increases the spring rate while dropping its load height and increasing it.
Sn 95 Will drop a coupe 1 1/2 inches with a lesser spring rate than a cut stock spring!! Increasing wire diameter and effective coils increases its load and rate at height!! DO THE MATH!! Just me being silly again.
So I need to get chucks mustang mounts for the struts but the springs pop into place with no problem? My car had "5 of ground clearance in the front already running stock suspension ( I think it is because of my wheel/tire combo. So should I really expect "3 of ground clearance in the front?
Quote from: SR71blackbird;418420
So I need to get chucks mustang mounts for the struts ...
Shocks, not struts, for the rear of the car.
Oh okay. I think I talked about this with you before chuck about getting buying mounts from you. When will you be making another batch?
Tom, I have to say, I didn't do any math. I figured it like this.....An SN-95 Stang weighs as much or more than my car. The SN-95 has a nice road feel to it (although tire types can change that feel). Soooo, I installed them on my car, and it did a few things.....1. It lowered the car about two inches.  2. The car drives great, like it did with the stock springs, but lower, and 3. Still hauls whatever I've always hauled (parts, groceries, people.....) without any issues at all. With so many people who have already used these springs, I'd consider them to be  tested and approved. If it was a whole new part nobody had ever used on these cars, then yes, we would need to look into that, but it's already been done. There's a thread on here somewhere that posts the spring rates and such on the SN-95 springs, and our stock springs..
Quote from: SR71blackbird;418426
I have some now, seeing as a couple folks who said they wanted some haven't bothered to respond. You snooze you lose.
Quote from: vinnietbird;418431
This.  They have been tried and used.  I dug into all the rates, etc back when I was at KB. I primarily wanted the rears, as I had other fronts, but the dynamics are close enough between the cars. The SN-95 spring thing has been discussed to death on this site.
Oh sweet! Can I buy a pair? If so, how would you like the payment?
See my posting in the Vendor section.
Soon i will be making adapter cups for the rear springs to accept the universal Eibach red series springs so choices will be unlimited. But i cant say when i would get them done, but when i do i will post them up in the vendor thread on here.
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
