Topic: Mass air running rich (Read 6589 times) previous topic - next topic
I have the new engine in and running but its running way rich, here's what it is....
1988 thunderbird turbo coupe
1999 Explorer 5.0
mass air
E-303
trickflow springs
1.6 roller rockers
65mm TB
Explorer intake
F150 fuel rail
BBK shorties
Offroad H-pipe
I'm beating my head trying to figure this thing out,  I know the first thing your going to say is pull codes....  well truth is I never really figured out the method.  I guess I'm looking for some ideas, but I know I need to know the codes other than system rich :toilet:
Buy a code reader. They are cheap. What is your timing at? I'm just curious.
Timing is set where you had the white mark on the balancer, I think 10 or 12 degrees.  I will look into a code reader.
Know somebody that has a MAF you can borrow?
Still on the 19#'s or did you go to 24's?
Parts stores have the code readers for about 40 bucks, +/-.
Read the Codes!!!
If the o2 sensors are bad it will default to a rich condition...
Which EEC are you using? I had to switch mine.
O2 sensors in the wrong sides??
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
81 and 82 are tad/tab sensor.
84 and 85 are egr/purge canister.
95 means you didn't run the fuel pump monitoring wire.
31 pfe/evp sensor failed below minimum voltage.
everything I see is emissions related.
Quote from: Haystack;413978
Yup, nothing suggests a rich condition, so unless both o2 sensors were somehow out of calibration(about a zero chance) it ain't happnin'...
matched wiring harness for oxygen sensors to transmission setup (manual or auto) and computer?
maybe a sticky fuel pressure regulator?
How do you know it's rich? Any gray smoke, exhaust burning your eyes, or fuel fouled plugs? It could just smell because of the lack of cats. An E-303 cam has some overlap which will make the exhaust smell dirty. Did you run a cylinder balance test? That test will tell you if you have a problem with an injector.
a bad injector or o2 sensor should have thrown a code. not saying it will though.
if you suspect bad o2 sensors, disconnect them and see if its still running cuddy. most of the time you don't throw codes and your running rich, its a maf/fuel pressure issue, in my experience.
