Topic: Mass air running rich (Read 6585 times) previous topic - next topic
I've decided to ditch the TC lines and F150 rail in favor of the stock/mustang style fuel lines and rail, after the swap is complete I will go from there. I really hate how the F150 rail puts the FPR under the upper intake....  I will also be running a different FPR with the new rail. I've ordered some new O2's so they will be going in soon also.
flip the upper around and use throttle body brackets off of a crown vic.
Quote from: Haystack;414028
Yeah, because THAT will do any good. :screwy::laughing:
why wouldn't it? from my understanding the fuel pressure regulator is just on the other side of the fuel rail. flipping the upper would be easy with no egr  in the way. then you just loop your throttle cable back around on the drivers side of the engine.
Because that's not really going to solve his issue..
88 how do you know you are rich?? Are you getting black smoke loading up ETC!!! You do not have any mixture codes as posted by by your codes.  Can you add any other symptoms just saying Thanks
pull a couple spark plugs and see if there's gas on them.
plugs are black, exhaust is harsh and burns your eyes and nose.  car wont start and stay running.
You're not getting fuel in your oil are you? Also, were the plugs wet at all?
did you un hook and.plug the vac line to the map\bap sensor?
MAP most definitely gets Vacuum.  BARO  does not get vacuum.
car is back up and running again, I checked KOER codes and it gave me 44 and 94. the car seems to be running better at this point although I havent had a chance to actually drive it yet.
