Topic: Rear axle id (Read 5020 times) previous topic - next topic
Rear axle id
For the life of me I can't seem to find "jcassity's" list of information! I am trying to read the axle information tag and I cannot find the correct codes. I would appreciate it if someone could help me.
Tag reads: V4978
              3L45  75  5C18
Thanks!
Rear axle id
Looks to me like you have a 7.5" rear w/ 3.45 gears.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Rear axle id
x2. must be a turbo bird/cat?
Rear axle id
Yea the l stands for limited slip but don't recall a 3.45 gear you sure it's not a 5 .......3.55
Rear axle id
Perfect! Yep, it's a limited slip with 3.45 gears from a turbo coupe. That's what I paid for. Thanks!
Rear axle id
Did they make 3.45 gears ? I have done a few just did a 3.73 swap for a buddy 7.5
Just never herd of a 3.45
Rear axle id
1st generation Rangers had lots of 7.5" rears w/ 3.45's in them......that's where I'm framiliar with them.  My fox cars have all had 8.8's.
Rear axle id
If my memory serves me right, (just don't ask the wife about that LOL) That's what I had in my 86 TC before the LSC swap.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Rear axle id
Right now all I have in my possession is a set of factory Ford Mustang shorty's and this rear axle then I can start working on the interior. Being my car has an AOD transmission I doubt that I will have much wheel hop. I am seriously considering Aerocoupe's suggestion to buy a set of CHE control arms for this axle. I still need to find out who sells the horizontal shocks. Thanks!
Rear axle id
Quote from: 86cougar;413534
I think local parts stores carry, or can bring in, the quad shocks. 4-5 years ago I picked up some from Autozone. I think they were Monroes or Gabriels.
Edit:
Gabriel 14039
http://www.autozone.com/autozone/parts/Gabriel-Steering-Damper/1988-Ford-Mustang/_/N-ihy8aZ8oxi5?itemIdentifier=8593_481907_20203_
http://www.amazon.com/Gabriel-14039-Steering-Damper/dp/B001AM5P48
1988 Thunderbird Sport
Rear axle id
Looks like they are easily available. I'm going outside to start getting this axle cleaned up for installation. I can't wait to see what a difference it will be from my stock 2.73 gear axle to this limited slip 3.45 gear quad shock axle will be like! Thanks!
Rear axle id
I put a track lock and 3.73 in my buddy's 96 v6 auto mustang
He had stock 2.73 and the 3.73 woke the turd up ..... Still a turd though lol
I'm sure you will enjoy the difference don't forget your speedo will be off some
Rear axle id
Quote from: STANG8U;413552
My poor car hasn't had a good cleaning in about a year when I started this project, cool thing is the engine compartment is cleaner than the rest of the car for a change. My new rebuilt "87" Mustang HO engine has about 200 miles on it now. I had the front end aligned along with rotation and balance today. I took off most of the garbage off the axle, so now it's about ready to clean up and paint. I'm trying to figure out which "CHE" package I should buy for this axle. I like having the option of being able to raise and lower the rear end. I bought the stiffest springs I could find (cargo on rear) so that I could cut 1/2 - 1 coil off to lower my car, then put 225/(50 or 55)/16 tires on it. An suggestions are appreciated!  Thanks!
Rear axle id
Just a point!!!
Pull the cover count the teeth and devide. This will accomplish 5 things
1 The rear ratio
2 If it has POSI
3 Change the cruddy oil and gasket and flush out all the particles. There is always some
4 Measure the ring gear for size. Should be a 7.5 and 3.45 ratio by the tag
5 Check the unit for wear and back lash
A 10 dollar gasket is all that is needed with a couple QUARTS of 75-140
Win Win Situation and problem solved !!!
Rear axle id
Quote from: TOM Renzo;413583
Just a point!!!
1 The rear ratio
2 If it has POSI
Tom,
        That's the fun part of cleaning, I get to open it up. I also take a can of brake cleaner and clean it out. I've noticed that the new gear oil is synthetic now and like you said 75-140w not just 90w.I did notice some oil dripping from the front of the pumpkin yesterday (where the u joint connects). Is there a seal there that will need to be replaced? Thanks for your help!
