Topic: Rear axle id (Read 5025 times) previous topic - next topic
Rear axle id
That's the pinion seal
Rear axle id
Quote from: STANG8U;413523
Did they make 3.45 gears ? I have done a few just did a 3.73 swap for a buddy 7.5
Just never herd of a 3.45
Early SVOs came with 3.45 ratio.
Ron
Speed is just a question of MONEY How fast can you go?    (M. M.)
Rear axle id
Learn somthing new every day lol
Rear axle id
I had the axle upside down and laying forward on the ground, so that is probably why it leaked. Thanks!
Rear axle id
Pinion seal needs to be replaced. But special procedures are required not to mess up the crush sleeve!!
No 7.5 came with 3.55 final drive ratio as far as i know!
Rear axle id
Quote from: BLKBRD88;413601
Ron
Along with all '83 to '86 Turbo coupes and no doubt some 4cyl Stangs......
Rear axle id
every 4 banger stang I've seen was 3.73 locker.
7.5 ratio rear only has 3,45 gears. 8.8 has 3;55. has to do with tooth count on the rear.
Rear axle id
Quote from: Haystack;413621
every 4 banger stang I've seen was 3.73 locker. 7.5 ratio rear only has 3,45 gears.
The mustang 7.5s also had 3:08s
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Rear axle id
should have specified...
the closest 3,55 ratio for a 7.5 is 3.45...
has almost  every other 8.8 ratio.
Rear axle id
Quote from: 1BadBird;413623
And 3.27s in some 5.0s
Rear axle id
Quote from: Seek;413540
I think local parts stores carry, or can bring in, the quad shocks. 4-5 years ago I picked up some from Autozone. I think they were Monroes or Gabriels.
Edit:
Gabriel 14039
http://www.autozone.com/autozone/parts/Gabriel-Steering-Damper/1988-Ford-Mustang/_/N-ihy8aZ8oxi5?itemIdentifier=8593_481907_20203_
http://www.amazon.com/Gabriel-14039-Steering-Damper/dp/B001AM5P48
Autozone had the Gabriels listed at $24.99 w/3 month warranty, O'reilly auto parts had the Monroes for $27.99 w/lifetime warranty. I bought the Monroes. They also come with shock boots.
Rear axle id
LOL every gear ratio has to do with TOOTH COUNT!!!!!!!!!!
:hick::mullet::toilet:
