Topic: Mustang driveshadt????? (Read 3195 times) previous topic - next topic
same as the tbird? i would assume so just wanna make sure before i order. THANKS
Idk the bird has a longer wheel base I think no ?
If so there are aftermarket spacer but none to thick
If they are the same you can go to the jy pull a aluminum off a exsploder Chang the yoke and call it a day
I think for the 5.0's they are the same
A Mustang shaft won't fit due to Thunderbirds/Cougars having a longer wheel base.
That's what I was thinking
Quote from: thunderjet302;408081
....what he said.....I totally rebuilt a Stang shaft and discovered the ''short coming'' when I went to install it.....duh.  :punchballs:
Do you have any local DS shops?
My buddy just had a custom aluminum one made for his 66 stang it was around $350 that's what one cost new from frpp
Check out Denny's http://www.dennysdriveshaft.com/index.html,  I don't know how much they are now but years ago I looked into driveshafts and spoke with these guys and it seemed like the way to go.  If you do get a quote on one let us know what they go for now..
MUSTANG
T BIRD
Thanks guys. Guess I'll look into getting one made.
Think I should just get a stang one n have it extended? I can get a used one cheap... car is a V8 C4 trans wth a 8.8
Not if its aluminum that's what my buddy tryed they can not do it
From what inland empire driveline said the ford one is  lol
Alot of us have the crown Vic police interceptor ds cut down for our cars
87 TC
Quote from: bigbada1;408106
Does it have to be the police interceptor?
My problem is I have tye stock one in the car, I drive the car to the track n wanna not have to worry. I plan on spraying the car hard out the hole so wanna no its not gonna break.
