Topic: Mustang driveshadt????? (Read 3204 times) previous topic - next topic
Also I have the typical mustang spacer would that help or still be to short?
Looks like its a lot shorter
Vinnie had one made from a Crown Vic aluminum unit.  Hang on and I will find the thread...and I found two.
http://www.foxtbirdcougarforums.com/showthread.php?31374-Aerostar-aluminum-drive-shaft/page2&highlight=aluminum+crown+vic
http://www.foxtbirdcougarforums.com/showthread.php?34196-Finding-An-Aluminum-Driveshaft&highlight=aluminum+crown+vic
Darren
Any one know of a car with a beefy D/S I can get from a junk yard? Besides crown vic. I got a price for $650 for custom n that's just not in the budget.
Thanks
The '90s Aerostars used a alum D/S similar to the C/V...
I've sprayed mine with a 150Hp shot and it hung together, stock except for solid Lakewood U/V joints...
Quote from: slowbird;408108
My problem is I have tye stock one in the car, I drive the car to the track n wanna not have to worry. I plan on spraying the car hard out the hole so wanna no its not gonna break.
Just for the record i have put hundreds of HP through a stock shaft with no issues at all. And yes i run aluminum shafts. But i have often asked myself WHY. Is it really worth the money and what for. A steel shafts works just fine set up correctly and balanced. Either way a custom shaft is in your future. They are relatively cheap all things considered. As far as i know a shaft can not be lengthened. Not successfully. just saying for what it would cost and the time involved it would not pay!!
BY the way Carbon shafts are the new THING!!!!
I know the shaft is lighter and easier to spin. I also know about the inertia losses of steel V Aluminum/Carbon. I ordered a Carbon shaft for the Midnighter. NOT CHEAP BY NO MEANS. But it is much better than Aluminum which i personally think they SUCK. Some are to thick!!!
Carbon shafts  are thinner to handle the same torque capacity as the aluminum .Carbon shafts have more clearance and requires less modification than aluminum. Aluminum shafts are normally thicker just saying. Then again my Anniversary Camaro came with an aluminum shaft right from the General Himself.
Quote from: TOM Renzo;408145
ya i know Carbon shafts are the way to go friend has one in his Outlaw 10.5 car. i am not worried about weight so i dont really care if its aluminum or steel just dont wanna be stuck at the track or along side the road. Car is a "BUDGET BUILD" rather spend $$$ on better heads ,etc if i could in the near future.
ford vans and trucks use aluminum shafts too...
I bought 2 aluminum Crown Vic shafts from a local place that dismantles the police cars. Got them for $35 each. My local driveline shop will size them for $125. I haven't got around to getting it done yet. I'm going to put one in my TC driver and one in my 87 TC footbrake project with a 550 h.p. 358 windsor. I've talked to plenty of people about the durability. They can take some big h.p. numbers. Anytime you can reduce rotating weight, you are getting more power to the ground.
All the local yards around me don't have the police car crown vics. I am check for a ranger tomorrow
Vinnie also said something about the crown vic taxi cars having them as well.
Darren
Yep. The taxis and cop cars were basically the same car as far as suspension and drivetrain. Many Taxis even had the Police pursuit badge on them.
There is no spacer that will make a stang driveshaft fit a Tbird.
The Crown Vic PI shaft is a full 3" dia, the Aerostar is 2.5, but if you get one from an AWD Aero, it will be Mustang length.
Just go with a CVPI shaft, have it cut down, and use the Tbird yokes, or else you'll have to get the hybrid u joints.
I wouldn't pay over 200 bucks to have it done....and if a shop says it can't be done, I'd move on to someone who can. Because there are tons of Stangs with aluminum shafts, and we all know they didn't come that way factory lol.
OP, all your questions have been answered, just search a bit, and you'll find the info you seek.
