Topic: 88 t-coupe 5.0l h.o. 60-1 turbonetics on3 performance (Read 6103 times) previous topic - next topic
Quote from: Monkeyturbochicken;407053
XXX
stock k-member?
Yup stock member. Suspension will be after she fires
The lower gear ratio loads the engine harder...which equals more power.  Its been proven over and over again.  3.73 are great for NA and supercharged cars...but for boost...the 3.55 and lower seems to perform much better.
Travis
Single 3" exhaust 316ss
Started the fab these pics dont show over the axle but it is done now just to put the tip on! Used v-band clamps and stainless bar stock for hangers. Anxious to hear it. Oh used magnaflow lerX:burnout:
Sweet....just to  cold here.
Travis
Ya cold here but the shop is heated. If i only had a lift id really be in business
Good call on the 90 fitting on the turbo feed line. Do you have a restrictor in there?
OH yeah, check the center section bolts on the turbo every so often, the one on my T67 and T76 both came loose after a few hundred miles. What stall converter?
There is a restrictor in, also manual trans.
Yes! Should be driving soon! All together and needs tuning. Got it wired last week(megasquirt) and it idles. Just need mire time
Sweet...need some pictures....or it didn't happen ;-)
Travis
Lol it happened! Just need to get my head into megasquirt. Idle is rough!!!
Have you started using tunerstudio?  I havent got there yet...pretty soon.
Travis
Yes, seems very easy. After the idle/correction maps
Sweet...well then sir a couple of pictures for us turbo loving Thundercats
Travis
