Topic: 88 t-coupe 5.0l h.o. 60-1 turbonetics on3 performance (Read 5735 times) previous topic - next topic
XXX
Sweet nice ride
I like this!
How well did the kit fit the T-bird? Thinking about the headers and engine mounts :)
Welcome :evilgrin: That's one sweet ride :burnout:
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Hi Jeff, its Dan I was down there and picked up the doors from you.  Ill have to see your set up in person sometime.
84 TC - under contruction
2018 F150 2.7 4x4 STX
98 F-150 XLT - 4.6, auto, 4x4, extended cab
The on3 kit fit great. Headers, mounts. And intercooler
Piping. The only issue i had was with the eletric fans. I found an old
Mustang and fast ford article that used a 95-00 ford contour fan setup. I went this route and it looks awesome and fits great. I would reccomend the turbo kit for any mechanic.
Where in IL are you??
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Now I'm kicking myself in the nuts because I went with Procharger for mine where I'm fabricating all of the piping and such myself and I know I'll eventually go turbo on my car :P
Im in lockport. I do have another intercooler piping kit id like to sell.
Thanks but I live in Sweden so I'll pass on that mate ;) Not that difficult doing it yourself anyways. Just a bit time consuming that's all.
What type of engine management are you using...  I have an ON3 351 kit in my 86XR7....not quite done.  http://www.foxtbirdcougarforums.com/showthread.php?32790-1986-XR7-351-turbo-swap....
What size fuel injectors...It should be fun when it is done.
Travis
I am just using a DA1 eec IV. Its a speed density eec. With 42lb injectors. A buddy of mine runs this setup with no problems. A lot of people say it doesnt work, but i have seen it. And if all fails them a megasquirt will be used
Quote from: Monkeyturbochicken;407381
I might just have to come take a look-see at your ride ;) ...... and check out that piping kit :evilgrin:  I'm not far way,
John
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Auto or stick?  Everyone on gods earth says to use 3.27 with a turbo mustang.  R heaver cars probably could get away with 3.55
I'm from Michigan. How far r u from me?
Travis
Ya anyone who wants to come and talk bird, im in. Im going stick with 3.73
Posi. I know all says a lower ratio but ive run 3.73
And 4.10 before. I like the shifting and the torque. Depending on where in mi you are. Id say at the furthest point 7hrs
