Topic: Still having an issue...UPDATE... (Read 13642 times) previous topic - next topic
Reply #60
sounds like a TFI to me
Reply #62
they weren't new, I dont think
Reply #63
or maybe the wiring coming from it?
Reply #64
The two distributors both came with new TFI's on them, and the one on my old distributor was only 3 months old. No change with any of them.
 I have a friend who is the head instructor at the vocational school for automotive tech. He said to bring the car Thursday and he'd put it on the machine and check it out. HOPEFULLY that'll find the issue.
Reply #65
Good to have friends with tools!!!  Hopefully you guys can find the problem and it will be interesting to know what is causing your headache.
Darren
Reply #66
Dumb question but you don't have any pinched/bare wires underhood do you? TFI and coil harness looks good?
Reply #67
That to is on the list for tomorrow. Wires and harnesses. I'm going to pull the upper intake and look at it all.
Reply #68
It could very well be a worn connection or a pinched wire around the salt and pepper shaker area. Could possibly be from all the intake swappage going on under the hood. Hell it could be a bad ecu ground or engine to chassis ground hope you get it all figured out vinnie
Reply #69
Vinny that is good to have a friend with a scope i am thinking. But getting it to act up not driving it could be a c. But either way Good Luck. Still sounds like spark but you can look at the scope pattern and tell a lean cylinder instantly. Hope you have good luck in finding it. I am thinking that the advance parameters may be messing up. As a back fire is normally late or lean. Dont rule out a vacuum leak.
:burnout::burnout:
Reply #70
I'm not ruling out anything. Wiring issue, spark...whatever. I don't even care if it's so simple a 3 year old should know it, as long as I know the problem and can address it, it's all good. I'm going tomorrow after lunch, and will report in when I get home. Or, report what we didn't find. Either wya.
Reply #71
Quote from: 87thunderbirdBlackJack;406579
All the intake swappage? Really? Me? You must have me mistaken with somebody else.
Reply #72
O.K.....I took the car down and my friend put it on the diagnostic ignition machine thing....He says that the coil isn't putting out but half of what it should as far as he sees it, and that the TFI is probably no good.
NOW, my current coil is an Autozone factory style replacement. It's under warranty. I can swap it for an MSD and just pay the difference, or should I go with another stock style?
As far as the TFI goes, I can get a Wells from Autozone, or an NOS Ford piece from my friend Mr. Ebay for around $23.00. I was told that Wells makes the TFI's for Ford. I personally have no bloody idea.
Any suggestions? Also, this is hopefully going to fix it, but nothing is in stone.
Reply #73
I've always run a msd coil with no issue ...... But m.s.d has always meant  my spark died lol
As for tfi they always go out no matter what brand it's just how soon lol
I really don't trust autozone stuff though
Reply #74
I have heard that as well.
