Topic: 87 Sport front brake hose replacements, help please! (Read 7520 times) previous topic - next topic
Im having trouble finding the correct replacement hoses for my car.  Everything that all the parts houses show have an inward flare on the fitting on the hose, but my cars hoses have an outward flare.  Has anyone else run into this?  Where can I get hoses?
I have a newer replacement hose that I installed awhile back on my 88 XR-7 that I will be replacing to do 11" upgrade.  It's yours if you want it , just message me your info and I can mail it to you.
Tim
Im needing to replace both of mine, they are rotting pretty badly.  Just trying to find if there was an uncommon hose setup used on some of the cars for some reason.  Ive already bought hoses from Autozone, and my mechanic says that they have the wrong flare.  Did some website research, and all the other parts houses (O'Reilly's, Advance Auto) have the same hose according to the pictures.  My cars at my mechanics right now and hes waiting on me to find a correct set of hoses somewhere.
Have you tried Rockauto.com, here's what they have.....
WAGNER Part # BH111933  {#F111933}
  F Brake Hose EXC TURBO COUPE; Base Model
Choose:
$4.32
Add Part
UBP Part # BH1079
  Front Brake Hose; EXC TURBO COUPE; Base Model [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
$4.76
Add Part
BENDIX Part # 77180
  Rear Drum brakes; Front Disc brakes; 10" x 1 3/4"; 9" x 1 3/4"; Rear Right
  Rear Drum brakes; Front Disc brakes; 10" x 1 3/4"; 9" x 1 3/4"; Rear Left
Choose:
$4.82
Add Part
AMERICAN REMANUFACTURERS INC. Part # 8734043
  Front Brake Hose RIGHT; 9" REAR DRUM
  Front Brake Hose RIGHT; 10" REAR DRUM
  F Brake Hose RIGHT; 9" REAR DRUM; Base Model
  F Brake Hose RIGHT; 10" REAR DRUM; Base Model [Wholesaler Closeout -- 30 Day Warranty]
$4.85
Add Part
DORMAN Part # H38260  {#E5SZ2078A}
  Front Left
  Front Right
$5.09
Add Part
EIS Part # SP6874
  F Brake Hose EXC 2.3L TURBOCHARGED; Base Model
Choose:
$5.27
Add Part
AMERICAN REMANUFACTURERS INC. Part # 8734038
  Front Brake Hose LEFT; REAR DISC
  F Brake Hose LEFT; REAR DISC; Base Model [Wholesaler Closeout -- 30 Day Warranty] (Only 9 Remaining)
$5.98
Add Part
EIS Part # SP6325
  R Brake Hose EXC 2.3L TURBOCHARGED; Base Model [Wholesaler Closeout -- 30 Day Warranty] (Only 4 Remaining)
$6.69
Add Part
UBP Part # BH1516
  Rear Brake Hose; Base Model [Wholesaler Closeout -- 30 Day Warranty]
$6.72
Add Part
DORMAN Part # H98945  {Click Info Link for Alternate/OEM Part Numbers}
  REAR CENTER
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I just looked at Rockauto. Looks like the same hoses. Im beginning to think my mechanic might be going crazy and is looking at something wrong.  Im supposed to meet him at O'Reilly's in a few hours to look at what they have and see if we can figure this out.  The guy at the store said that the hose they can get matches what my mechanic says we need, even though the pic on their website doesnt look it.
Ok, well apparently there are no hoses available for a Thunderbird that fit my car.  Idk wtf is up with that.  So, we ordered new calipers today in hopes that the new hoses will fit them. Fortunately calipers are cheap.  Just hope they work.
Ok, the new calipers dont work either.  They are the same flare as what is factory on the car and wont work with the new hoses.  Guess its time to find someone to custom make them.
when I ordered my flex hoses from rock auto...they didnt match the picture..... but they fit the calipers I ordered them for
Unless your car has already had the 11" brake upgrade done to it, your Thunderbird should take same calipers and hoses as 4 cylinder mustang.
I was about to post that.
The 4 banger stangs have the same brake system as our cars. I seem to remember ordering one when my tbird ones were out of stock.
This is what shows to fit my car:
http://www.autozone.com/autozone/parts/Brakeware-Brake-Hose-Front/1987-Ford-Thunderbird/_/N-iilgfZ8knp9?itemIdentifier=752345_166223_3559_
This is what shows for a 4 cyl Mustang:
http://www.autozone.com/autozone/parts/Brakeware-Brake-Hose-Front/1987-Ford-Mustang/_/N-iil81Z8knp9?itemIdentifier=21212_166223_3559_
Both are pretty much the same thing except the fittings are different sizes.  Both have the wrong flared end.  Neither will fit my stock calipers, or the new calipers I ordered to try with the new hoses.
Go to a hose a nd rubber store house with the origonal parts. They will probably be close to the same bprice, or cheaper.
Thats kinda the direction we are looking now.  Is this just a weird variation on my car?  If so, I cant help but wonder why the new calipers were the same style.
Can you post pics of whats different?
I dont have my car its at my mechanics.  The only difference is the flare on the end of the fitting that screws into the caliper.  The new hoses have an inward flare, and the factory hoses have an outward flare.  The new hoses thread in, but probably wont seal good since its the wrong flare.
Heres some pics of the difference in the flares taken from the internet.
Wrong flare:
http://brakefittingsclicks.blogspot.com/2011/05/aas-brake-line-adapter-210-45-10pcs-f.html
Right flare:
http://ribetautoparts.com/metric-bubble-flare-iso---brass-brake-line-adapters---3-16-tube-female---12mm-x-1-0-male-thread-bubble-flare.aspx
