Topic: 87 Sport front brake hose replacements, help please! (Read 7477 times) previous topic - next topic
napa had an adaptor to change from the top pic to the bottom pic...
Ill check Napas website.  TY
I believe it one of these you need
If i read this correctly you have an issue with the inverted flair end on the hard line??? That is correct and an adapter and or a tubing cutter a new line fitting and flaring it and bingo you are dun. The left side has a bigger inverted flare nut.
That is strange.  Well, you learn something new everyday!!
Well the Turbo coupe has different lines from left to right of course most cars do. But the fittings are different. The right side has a bigger inverted flair fitting that takes a standard 3/16 line. The drivers side has a smaller inverted flair fitting that also takes a 3/16 line. This is very common on cars that for example have ABS controllers. They make the fittings different so they dont get mixed up!!!
Yes Daminc, that is what Im looking for :)  Needing 2 actually lol.  Where can I get those?  If it was a parts house, did you happen to get the part #?
Quote from: TOM Renzo;403152
No, the flare on the hoses, not the hard lines.  Daminc has what Im looking for there in his picture.
Quote from: Outhet;403234
no part #...they opened a drawer behind the counter, and pulled out 2 for me.. I would assume any parts place would have those fittings. I like to keep things like that on hand for obvious reasons
I must be dealing with complete idiots here then lol.  What parts house were you at?
Napa
Quote from: daminc;403255
Napa
Lol that figures. Guess Ill try all the local places again and then head to the next town over and check the Napa.
Stainless, not brass.
(Brass will leak).
mine never leak
Daminc is that not a step up inverted flair adapter??? It looks like it and that is what i am talking about!!! Been their many times and i just installed the correct fitting and re-flared the hard line.  But adapters  work. Hard line ends and adapters are available at NAPA. I thought i explained it back a couple of posts!!
