Topic: Need help to id (Read 4689 times) previous topic - next topic
Need help to id
The car came with rear disc brake set up just don't know of what, it has a nine in under car.  Need Id the calipers so I can get new hose. XX
Need help to id
They look like there from a 1977 Lincoln Versailles.
Need help to id
Guys at napa today show me pic from a 1976 tbird with nine inch and rear disc
Need help to id
I would second the Versailles.  I bought one to install in the '69 Fastback as it is a direct install.  The calipers were very odd in the way they bolted on.  We ended up ditching the brakes, narrowing the rear and installing '05 Mustang GT rear brakes.  Easier to get parts and the aftermarket is alot bigger for those brakes.
Darren
Need help to id
Is there a bracket you get off the 05 and just switch them out, so I can mount the calibers?  Newer Calibers sound good, but i will use this for now and look for other later.  How much is it to narrow up a 9in you think?
Need help to id
No.  The axle housing ends on the Versailles are pretty unique.  We narrowed the rear end and change the bearing ends.
Darren
Need help to id
Is the Versailles rear already installed in a car?  If is it or is not installed what car is it installed in or are you wanting to install it into?
Darren
Need help to id
Yes already in the 83 thunderbird.
Need help to id
Well then the spring perches are long cut off and it has all of the brackets on it for the four link.  What you have to know is what size axle bearing the rear end has as there were two different ones.  There are three patterns on the axle  which will let you know what you have:
"Small Bearing" - 3.375" by 2.000" pattern
"Early Big Bearing" - 3.500" by 2.375" pattern
"Late Big Bearing" - 3.562" by 2.000" pattern
Here is a good page so you can see what I am talking about:
http://www.steeltechsolutions.com/REAR_AXLE_ID.html
What you are hoping for on yours is the "Late Big Bearing" as that is what the Explorer uses so you could use the M-2300-G2 kit and put the Explorer brakes on it as another option.
Darren
Need help to id
I will check that out thanks, I will let you know what I have
Need help to id
Looks to be (late) by the measurement
Need help to id
I took wrong pics, disregard the pics
Need help to id
I measure the ends at 3.5 x 2
Need help to id
I would say that the Explorer brakes would work then.  That would be your easy solution and they are far more abundant than the Cobra parts.  I would think you could get all of it out of a salvage yard for cheap.
Darren
