Topic: Need help to id (Read 4685 times) previous topic - next topic
Need help to id
nine inch little wide
X
Need help to id
Three choices there:
1) Change the wheels to an offset that moves the tires inboard.
2) Swap rear ends to a 94-98 Mustang GT rear end
3) Narrow the existing rear end
All of which are not cheap but the cheapest would be to get different offset rear wheels.  If you choose this route wait until you swap in the Explorer rear brakes and then see if that changes anything.  It should not but better safe than sorry.
Darren
Darren
Need help to id
I might sell and do the rear end later, is what I was thinking.
Need help to id
Darren I was ready over this and do you think I will need a special bracket to fit the explorer calibers on there?  I having a problem with a sticking rear left side, so I was thinking of doing the explorer calibers, but unsure if its a direct bolt on kit.
