Topic: Clutch cable (Read 1807 times) previous topic - next topic
Clutch cable
My buddy had already installed clutch pedal setup, my question is where to drill hole for cable to come out, and what size hole, any pictures of someone doing this mod?
Clutch cable
There should be a hole already in your firewall with a grommet in it.  At least it was there on my '88.
Clutch cable
I am going use the hole where the speed cable went, I have after market gauges for dash.  Thanks
Clutch cable
With the hood up, and looking toward the firewall, the clutch cable hole will be to the left of, and slightly below the top of the brake booster.
The older cars, that may be where the speedo cable enters...on the '87-8 cars though, we had electrical speedo, so that's where the cable goes. Unless you have a TC, which of course those were hydraulic, stock.
My thought: look at an 85 or 86 TC or XR7, as those cars had cable clutch (and probably speedo senders instead of a cable, so it's probably not relevant anyway).
Clutch cable
I have a electical speedo from cyberdyne gauges
Clutch cable
Look on the firewall and there will be a dimple already in the metal as to where the hole needs to be.  At least it was there on my '83.
Darren
