Topic: Looking for brackets and pullies.... (Read 2460 times) previous topic - next topic
Looking for the factory a/c-power steering bracket and the alternator bracket for a 5.0. Also, stock pullies. The alternator pulley isn't necessary, but the crank, steering pump,and waterpump pulley if possible.Cheaper the better. trade, whatever. let me know.
Anybody got any T-Bird /Cougar 5.0 brackets?
Still looking for the brackets.......
I have those 3 brackets right now from an SO 5.0, which came out of an '87 Crown Vic. Not 100% sure if they are the same as the 5.0 Fox configuration though. If they are lemme know, and I'll dig em outta my parts bin and get some pics for you.
The Crown Vic uses different pieces. I appreciate the offer though. A lot.
My yard has 2 87 5.0 cougars its going to cost you, I don't like to get dirty.lol.......
Do you have any turbo coupe rear disc parts??
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I have no disc parts at all. I wish I did. I'd be glad to pass them along. I need the brackets and associated pieces...bolts, tensioner, and a/c pieces (not the big black steel brace up front or the steel "rod" braces). What do you think you can get them for?
Updated the needs list.......
I'll look I might have those from my car
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Kep me posted. I'm working 12 hour shifts the next three days, so it'll be later before I get back. Thanks a lot, and no hurry.
Let me check the 90 mustang I pulled my motor out of at Dad's the brackets might just be laying on the ground, I also think I have the front pulleys from a 2000 explorer but they are a bit different. V8 Ranger guys want them cause it bring everything super close to the motor. Will be this weekend before I get a chance to look.
I'm just wanting stock T-Bird/Cougar stuff. The alternator bracket from the Stang 5.0 would work, but not the a/c stuff.
so I have nothing in my attic, i will try to get to the yard this week
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Vinnie, what do you need yet, I found a 87 TB last weekend , engine and everything was in it, If it's there tomorrow I'll grab what you need, I know pulleys are 5 bucks, i don't see prices for brackets but I'm sure there cheap, Let me know. It was pretty intact last Sunday,if anyone else might want something.
I need a waterpump pulley,Crank, and steering pump. And the alternator bracket, and the power steering/ AC bracket pieces (No compressor, but the rest....bolts to if you can). I'll also take the throttle cable bracket and water pipes from the lower if you can get them. And, a trunk mat if it still has one in decent shape. Thanks Kitz !!!
