Topic: Looking for brackets and pullies.... (Read 2477 times) previous topic - next topic
I'll see what I can do for you. Hopefully it wasn't raped in a week.
Thanks Kitz. You know where to find me.
My short list....
Timing pointer
brackets and the fasteners
pulleys
water pipes for the lower intake
throttle cable bracket
5.8 distributor with the TFI on it (or a place for the TFI if the TFI is missing)
A 94 and newer F truck with the 5.8 will have the distributor you need. Has to be newer though, otherwise the gear won't work with the roller cam. ( i think)
One with a steel gear would be what you seek. Also, the oil pump drive shaft...5.0's use a shorter shaft I believe, as well as smaller. I've got two different sizes in my pile 'o motors, and I only have 5.0 and 5.8 stuff.
I know I don't have any TFI dizzy's for a 351w though.
Thanks Beau. The distributor was the only thing missing from the engine when I got it.
I *may* go to the yards next weekend...if I go, and meet a 5.8 truck, I'll nab the dist for ya.
9 wires, a TFI connector, and a bolt, and one yank, and it's outta there. I even have a magnet tool to fish out the oil pump shaft lol, provided it doesn't drop into the pan..
TFI connector? It just plugs into the TFI on the side of the distributor like our 5.0 does. Maybe I'm misunderstanding what you're saying. I don't want to go to a remote TFI.
I checked for you in 3 different yards today, during my run earlier. Only found one solitary fox Cougar, and when I popped the hood the 5.0 was already gone. Didn't find anything that I needed either. Fox shiznit is getting  hard to find....
Yep, super hard to find, and still has no actual cash value. I wish somebody would start making a few aftermarket pieces.
vinnietbird are you still looking for pulleys and brackets? I have a throttle cable bracket from a fox body Mustang 5.0 which is identical to the 86 T-Bird one I found except for a small opening at the TV cable hole. I have a water pump pulley and crank pulley from a Mark VII 5.0. I also have an alternator bracket from a Fox body Mustang 5.0 but the ears for the air pump have been cut off.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
I didn't forget you. I'm going there this morning. Hopefully its still there.
Like I said, no rush at all. I'm guessing this is a year long project. Thanks a lot Kitz. You da man.
I pm'd you Vinnie.
