Topic: New Here 83 Thunderbird (Read 69901 times) previous topic - next topic
Reply #225
X
I also worked on the shifter boot.  I had the console from the parts car, which was an automatic.  I got an 85 model manual bezel, but did not fit very well on the console.  So I cut the bottom of the coin tray and then made a pattern to cut out the manual bezel top the place down in the tray.  I have not found a way to fasten it down yet, so it is just laying in the tray for right now.
Reply #226
X
Reply #227
Coming together nicely. Keep up the great work. Have you decided on a type of seats yet?
 S O L D
Reply #228
not yet, looked at some of the seats on Ebay, but have not looked to hard yet.
Reply #229
X
X
I have the radio and eq powered up, I also ran the RCA's and speaker (16ga) wires.  I ran two speaker wires into the door, mid and tweeter.  I will put crossover somewhere in the back with the amps.
Reply #230
X
X
Reply #231
What brand speakers are you going with? I hope to update my stereo over the winter. I have some older Rockford amps that I want to use.
 S O L D
Reply #232
I am using my Punch 60 for subs and Punch 4020 for mid and highs (old school).  Probably some MB quarts for the 6.5 and tweet components in door.
Reply #233
X
X
My trunk lid was never painted, jammed it, and I put the cover on
Reply #234
I like the old school stereo setup
I bet it'll sound good too
I have these older Rockford hx 10" single coil subs that I got free at work a while back and I kid you not I've blown like 2-3 amps on them since using them haha,  dang tough subs
I'm actually going with a component setup atm but I might end up with some different subs lol
Reply #235
X
inner window wipe (or seal) in place, now time for door pops, speakers, and fix up the door panels.
Reply #236
Quote from: 83TB;451795
X
X
I like the trunk lid cover..( wish mine had that) ..Gives it a clean, finished look.
 S O L D
Reply #237
X
Its been a bit, but I finally got my steering wheel on, not laugh at the floor mats, just temp ones while working on the inside still.  Seats and finish up door pops and panels, then I can move to the system in the trunk.
Reply #238
X
X
Dodge SRT-4 caliber seats mounted up in the t-brid
Reply #239
Sweet!!! Comfy looking seats
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
