Topic: t5 swap (Read 3918 times) previous topic - next topic
t5 swap
So since it looks like I will be swapping in a 5.0 and I'll need to go to floor gear selector, I'm thinking of just dropping in a t5. My question is will a Mustang t5 Cross member work on the bird? Thanks
t5 swap
It should be fine. I just used the crossmember that came with my Sport. Everything bolted right up. Even reused the AOD's tranny mount.
t5 swap
Quote from: vinnietbird;394640
I also re-used my birds "double hump" crossmember.  Unless there is a difference between 87 and 88, yours should be fine.
t5 swap
Alright thanks guys yeah I have the double hump cross member, just don't want to be bolting everything back up and realize it doesn't fit.
t5 swap
You may have to grind the spot welds on the tubes that are on each end of the cross member so you can adjust the cross member from front to back.
Darren
t5 swap
I think I may have just flipped mine from side to side.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
t5 swap
I just re-installed mine..no flipping, grinding, or alterations.
t5 swap
Mmm alright even if I have to grind something better than buying over priced used mustang parts here in California, to people that have done the swap how much did it run you? Is 5-6 hundred reasonable estimate going from a 3.8?
t5 swap
5 or six hundred dollars for what? Engine and tranny? Just the trans,? Harnesses? Give more details.............
t5 swap
What do you already have? There's a 5.0 Stang here ('95) with the T-5. He said I could have it all for $250.00. Trans, bell housing, cable. I may get it. The SN-95 5.0 cars with the T-5 will bolt right into ours, but you have to have the SN-95 bell housing as well.
t5 swap
I have 2 bells for sale. If you need one that is!!
t5 swap
Sorry should have clarrified. For the 5.0/t5 swap into an AOD 3.8
t5 swap
I have nothing parts wise as I was thinking about the 351 swap but after throwing some numbers together I know it's way out of my price range.
t5 swap
If you were here, I could get you an H.O 5.0 and T-5 setup nearly complete for about $600.00. I pulled the pullies and distributor from it, but it was a known good running car. If I had the cash to spend, I'd buy the assembly, but, I'm shooting for the tranny stuff.
t5 swap
Quote from: vinnietbird;394684
That's cheap!
