Topic: t5 swap (Read 3920 times) previous topic - next topic
t5 swap
Guys, be careful with the SN95 5.0 tranny.  It actually has a longer input shaft that locates the transmission further back in the car.  You can swap the input shaft very easily to the Fox lengh unit which a lot of Mustang guys have done.  As Vinny mentioned you will need the 94-95 T-5 bell housing but make sure you can stand the shifter futher back.
Darren
t5 swap
I wish i was closer to you vinnie,ill have to look around maybe source the t5 from a junkyard would one from a soupercoupe work? Because there were about 6 sc's in jy last time i went.
