Topic: Somebody else makes sub frame connectors for our cars! (Read 6862 times) previous topic - next topic
The place is called alston race cars, here is the link.
https://www.secureway1.com/alston/index.php
Cougar on a diet to suck gas and haul ass!
Cain, Pony Express Racing
i didnt see anything about tbird stuff there...
If you guys are looking for full length SFC's, I can fab them up.  It takes 10' of 1"x2"x.120" wall tube ($30-35), couple hours of cutting and welding to close up the ends along with side tabs if you want to bolt them on.  Using 5' per side will run you from the rear LCA boxes up to the front almost where the frame rails curve up.  Could do them for like $85 per pair plus shipping.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Quote from: Dan B.;392949
If you close up the ends like this  (front)  \=======\ (back) instead of (front) \=======/ (back), you can get a couple more inches of welding onto the rear subframe.  Unlike on a Mustang, the rear frame rail dips down behind the torque box.
Not sure how you're doing them, but that's how I did them when I made them (and when we were doing them at KB).
Adding a crossbar under the seat supports really helps things out too.
Got any pics of a set you've made? I'm bout in the market from some (car is moving under own power again)
Go to the subframe connectors section and there should be a pull down option list under weld in and bolt in, in those you will find our cars.
Quote from: Chuck W;392956
That's how I did them.  I could add a crossbar with no problem.
Quote from: Soul;392960
Don't mind the bubblegum welds at the attachment points...was teaching a friend to weld overhead.  I did all the welding and clean up on the ends of the tubes.
Rear
Front
When I installed the KB SFC's in my car I found it hard to weld onto the subframes because they're galvanized. You'll have to do some grinding to remove the magnesium to get a decent weld...
Quote from: Thunder Chicken;392981
I did.  I'm going to go back and revisit Rick's welds and add in some side plates.
I put side plates on the rears of mine
Quote from: ThunderbirdSport302;392946
Did you find it?
Quote from: Dan B.;392972
Rear
This is what I was saying.  Flip that closure over the other way (put the flat portion on the bottom, not the top) , and you can extend the tube back onto the rear subframe.
Kind of a py pic, but... (And don't mind that I apparently forgot I had jacking rails on the car when I jacked it up :p)
I'm afraid I'm not seeing the difference clearly
Quote from: hypostang;393023
Look at his first pic.  Flip that closure over, and you can extend the bar rearward onto the subframe another 2"
