Topic: Warning !!! 3G Warning!!! (Read 1763 times) previous topic - next topic
If anyone is using a 3G with the 90 degree adapter on it *PLEASE* do a periodic check on your connections .X
I was sitting in a parking lot last night idling with my A/C on and noticed a funny smell . I opened my hood and the plastic on the adapter was actually on fire.
I put the fire out and "rednecked" the car so I was able to get home .
 I have a voltmeter and the car was charging in range when this happened .
I am very thankful that this happened while I was parked rather than while driving or it could have been catastrophic.
Apparently my connecter got loose or dirty...or both.
I went to the JY and got a new alternator without the 90 degree thing so I shouldn't have any more problems.  But I wanted to post this so no one else has any trouble .
I'll be checking in the morning thanks for the heads up
hmmmm,,,,,,,,,,will be looking at the bird tomorrow
thanks!
You know, when you open up the alt, there isnt really any mathmatical logic to the amount of circular millimeters of copper provided to proof out a max ampacity of a 3g.  they must be using 60degC connectors and such because our connector(s) dont have a temp rating on it nor what i can find on a spec sheet, when that happens then you have to use 60degC wire or copper tables.
Id gander that you had a loose connection... remember to use No-Oxide.
scott
That is a typical loose connection  in my view. Always use compound and torque the nut with a star washer behind it. And never use one of those nuts with the washers that swivel. Use a standard nut with a star washer. That connection got plenty hot from resistance. My money is on a loose nut!!!
Quote from: TOM Renzo;392120
 I would agree totally loose connection  , the thing is that is a factory connection that I never really touched , in hindsight I certainly should have ...lol
