Topic: prop valve installation under dash or under hood (Read 1298 times) previous topic - next topic
it's an adjustable
i'm not sure how i can do it
some suggestion with pics !!
Pretty sure if you ever plan to race it, they (whatever sanctioning body) will keep you off the track for having flammable fluids inside the car...so definitely under hood for it.
Plus, it's not something that you'll be constantly adjusting. Set it, and forget it. :)
Quote from: ThunderbirdSport302;388257
;)  AFAIK, brake fluid isn't flammable.
You can mount it pretty much anywhere you want, but under the hood is best for a street car.  Once you get it dialed in, there's nothing else you need to do with it.
^ Errr yeah, for some reason, I was thinking brake cleaner, not brake fluid..brain fart I guess.:rollin::shoothead
for sure it's easier to put it undr the hood for the linings
it's gonna require a couple of in and out the car to set it well
thanx for the replies
Yeah, under the dash would require a lot of plumbing for something you'll set once and leave alone...
have all my fittings
doing this t-nite
will set it under hood
