Topic: Transmission Mount '88 TC (Read 3904 times) previous topic - next topic
Was ordering some Energy Suspension pieces for my sway bars, rear control arms, and such. I wanted to order an Energy Suspension trans mount to but the image Summit shows doesn't look compatible with the t-5 TC mount.
Anyone tried it or have any other suggestions for a trans mount?
Link to trans mount at Summit.
http://www.summitracing.com/parts/ENS-4-1104G/Application/?prefilter=0
...and there was light!
That is the correct mount.
Are those regular rubber bushings?
or polyurethane or maybe a mix?
Oh never mind....
Tom are you sure? I remember my TC having a single stud coming out of the bottom, not two studs? Thanks for the help!
Haaa Just noticed that it has threads in the center, so you could just use the center whole instead of the outside wholes. Right?
i just checked mine, it's a single stud.. a rustang crossmember would give you the 2 stud slots, if you really wanted to go that direction
LOL didn; even notice.. what a bi.. you know.. lol
I had one of those and couldn't use it with a 88TC crossmember. I had to go with the single stud style and returned the poly part.
Quote from: flylear45;384702
Why couldn't you use it?
The 3 hole is the correct one. I have used several over the years. Or get out your MAKITA  that makes it fit for sure if it is a two hole !!!!!!!!!!!!!!
Quote from: TOM Renzo;384720
After realizing that it has three holes I feel sure you are correct! It was one of the several items that I ordered today, so we will know for sure in a couple of days.
Thanks for the help Tom!
i demand updates of your install.. by the moment! lol i think i need a new 1 for my lone 4 banger.. when i checked to see if it was a single or double earlier.. lets just say it didn't look like a rubber mount anymore lol
I will install it as soon as it gets here, mine is toast as well!
I have a vibration above 70, that comes and goes depending on throttle position, that I just can't find. I have replaced tailshaft bushing, universals, then driveshaft. I am going to replace the trans mount and if it doesn't fix the vibration (doubtful) I am going to yank the entire rear out of one of the other cars and replace the whole rear! So needless to say I am getting desperate for it to go away! lol
