Topic: Transmission Mount '88 TC (Read 3926 times) previous topic - next topic
mine can't vibrate.. it doesn't move and currently sits turboless :) lol
LOL! That definitely cuts down on the vibrations!
...and there was light!
doesn't help when BJL drives past my house and revs his car :( he's a big meanie.. he not nice to me.. LOL
seriously, there's a possibility that the vibration could be coming from your toasted trans mount.. you figure at those speeds, any little weak link can give you trouble
I can grab the back of the front of my drive shaft and move the trans side to side, so it very well could be the trans mount. But if it isn't the only thing really left is the rear, I just can't think of anything else that would give this kind of vibration! I plan on taking it on a 950 mile round trip here in a few weeks and I will be dang gone if I want to deal with this vibration for that many miles!
oh .. yeah.. i'm going to bet it's the mount.. if you can do it by hand, just imagine what your driveshaft is doing to it at 70+ lol
I hope it fixes it but just in case it doesn't, I went ahead and ordered all of the bushings for the rear control arms and everything to rebuild the brakes on the other rear! :D
good luck, i hope i'm right and it's the mount :) lol
That mount is shot and it is good you are replacing it. You also get rid of all the junk related to the stock mount. Good call on the replacing it. The stock ones suck!!!
Think I found my leaning problem .....
Both the green ones came off the same car! Sadly my new ones are shorter than the factory ones .....  grrrrrr lol
Links will not cause or correct a LEAN. Just Saying.
Quote from: TOM Renzo;385285
That makes me sad :( ......  lol
I am going to go ahead and install the new ones, I don't see where the length matters to much as long as they are the same.
you should be alright with the new E.S. endlinks but why is one of the old ones appear longer in the center sleeve area then the other one??
