Topic: Project ludicrous speed! (Read 8973 times) previous topic - next topic
Looks great!!!
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Looks great. Like the fender protection, I hate wrenching over nice sheetmetal.
Hope it runs like a raped ape!  Looks great!
Mike
Looking good so far
It runs! I should have taken more pictures of the process but I just got so wrapped up in working on the car that I forgot to take pictures of the rest of the "build". I had a bit of a scare when I fired it up last night because it was smoking out the exhaust pipes really bad and it looked like burning coolant. It was buring coolant. What happened was that when I removed the GT40Ps a bunch of coolant overflowed from the block into the exhaust when I removed the last lower head bolt:hick:. I ended up sticking the bolt back in and getting a funnel to route the coolant to the pan I had under the engine, but not before about a half a gallon got into the exhaust. It took about 20 minutes to blow the coolant that got in the exhaust out. After that no more smoke and both the oil and coolant are fine. I haven't really beat on the car yet as I'm still "breaking it in" but it will lay rubber from a 20 mph roll now :burnout:. It feels noticeably stronger, especially in the upper RPM ranges where the GT40Ps started to fall off.
I take some pics after I redetail the engine bay. I chipped the heck out of the A/C lines and some of the brackets working on the engine so they need to be cleaned and detailed again. It looks just like it did with the GT40Ps, so no one will be the wiser that it has some nice flowing aluminum heads;).
Congrats !!! I'm proud for you. I'm really interested in the horsepower numbers. Were your "P" heads ported or have they had any work done to them? Reason I ask is, I had mine ported and the whole 9 yards, and I'd be interested in knowing how they do compared to aluminum heads. I just talked to my friend who runs the local Vocational auto classes, and he said I could use his dyno soon. I can't wait for that. Gotta do a fine tune on the old girl.
Good work man!  I can't believe how clean your engine bay is!
Great work! I'm glad your scare didn't turn out to be anything major.
Quote from: vinnietbird;390181
My GT40Ps were stock except for the exhaust valves and springs. The exhaust valves were replaced with ones that were taller and didn't use valve rotators so they worked with non stock springs. Other than that stock as cast. The car is noticeably stronger with the new heads. Like I said it will spin the tires from a 20 mph roll.
I got some pictures of the engine. The bay needs some detailing attention but you can see how well the paint hides the heads. The casual observer would be hard pressed to tell that the car has Edelbrock Performer heads, which is how I like it ;).
Quote from: 1Bad88tbird;390203
I kept watching it yesterday but no more smoke came out. The engine oil and coolant levels didn't change so it's fine. I really didn't want to have to pull it apart again.
Quote from: thunderjet302;390147
we need a video of that
Your bay continues to amaze.  Even your spark plug wires are clean and arranged perfectly!
Quote from: xjeffs;390340
Maybe more like spin the tires. I'm not sure if it left any rubber but the wheels were spinning :hick:. Unfortunately living in a highly congested urban area I don't have an area that I can safely film, uh, "activities" in. I'll have to take a trip out to the boonies ;).
Quote from: 50tbrd88;390351
The pictures make it look better than it really is right now. The plug wires are dirty and there are chips all over the A/C lines and front accessories.
