Topic: engine stand (Read 1019 times) previous topic - next topic
engine stand
I want to pull my buddys blown motor out. Is that a certain engine stand i need or will any work?
engine stand
Just remember to take the flywheel/flexplate off first and you're good to go. Every stand I've seen has movable arms to fit all motors. You might need to make sure you have the right thread bolts to hold it there though.
engine stand
correct, any stand should work.. but most stands allow you to leave the flywheel/flexplate bolted to the crank.. clutch will definitely have to come off, if it's coming out of a 5spd car
engine stand
Okay sweet thank you very much!!
engine stand
you will need some long bolts for the lower 4 holes to attach to the stand since they are not threaded.
