Topic: 2.3 built head (Read 1059 times) previous topic - next topic
2.3 built head
This is just a tester post for now to see if anybody would be interested in my cylinder head. It has a full Bo-port roller assembly with larger valves and a stage 2.5 cam. It is fully ported. I'll be selling the head within 2 months. im curious what people will be willing to pay for it.
2.3 built head
This head?
Quote from: SR71blackbird;383287
When i start my car up, a puff a blue smoke comes out. Ive been told it is a valve stem seal. I am hearing chatter from the valve train
Im thinking the shop i had build my cylinder head had a bunch of monkeys working on it!
2.3 built head
lol bingo! But from the people ive talked to, it is just the valve stem seal. Also, the chatter goes away in 15-20 seconds after starting the car. So that is a cheap easy fix. My buddy blew his motor so im taking his head and putting a stage 3 cam in it. I'll take it to a different local shop after i take it off and have them check it out and clean it before a sell it.
2.3 built head
valve stem seal*^^^
2.3 built head
What would you like to get out of it?
2.3 built head
Well right now the figure is around $1000-$1200. I have just over $1800 invested. It will be cleaned and checked for cranks before i sell to insure it is in great shape.
2.3 built head
Man I got riped. I sold my old ported big valve head for alot less than that.
2.3 built head
Yeah id say you did! similar new ones are around $1900.
2.3 built head
It all depends on the experience level of the person who ported it, what it flows, and what cam/valvetrain it has in it. A "Bo" head carries more value, due to reputation, than one ported by the local speed shop who doesn't really know the 2.3 head.
2.3 built head
it flowed 215cfm intake and 180 i believe on the exhaust. It was full boport cam-valve train.
2.3 built head
THERE HAS BEEN A CHANGE! instead of selling my head, i'll be selling my friends head.
It has a full boport valve train with larger valves with boport stage 1.5 cam and has the bowls, guides and 3 angle valve job done to it.
$700 after cleaning and checking.
2.3 built head
It is in perfect condition
