Topic: Parts left over from '87 TC part out. (Read 3255 times) previous topic - next topic
I took a break for the last couple of months, now I'm back. The car was pristine and well taken care of. Some good stuff and also a lot of odds and ends. All parts are in top notch condition. Prices don't include shipping. Here's what's left with lots of pics.
Motor mounts, very good rubber - $40
ABS master cylinder, good and working - $75
Turn signal switch, good lettering - $20
Windshield wiper switch, good lettering - $15
Fuel pump hangar - $15
Electronic climate control. I've got 2 of 'em.
$15 each.
Rear speaker covers - $15
Door speaker covers - $10
Hood scoops - $20
Glovebox (raven) - $15
Trunk weatherstripping, soft and supple - $20
3 armrest lights. 2 driver side/1 pass side - $5 each (only pic I had, inner light is gone)
Seatbelt retainer on seat, driver side - $10
2 seatbelts, 1 dr/1 pass - $10 each
Factory boost control - $15
Armrest (raven), pass side, all mounting tabs intact - $25
Armrest pad, pass side - $10
2 door lock panels w/working switches - $20
2 new door lock panel transfer decals to go with above - $15
Console tray insert w/very hard to find factory storage bin - $30
Factory gauge cluster, all gauges work - $35
Gauge surround trim - $20
Steering column trim, 3 pcs (raven) - $15
Misc lower dash trim (raven) - $5 each
TurboCoupe & TBird trunk emblems - $10 each
Kick panel, pass side (raven) - $15
Complete lockset w/keys. 2 door, 1 trunk, 1 ign switch and door keypad - $35
Swaybar end links w/polyurethane bushings - $15
Headlight switch panel w/switches - $15
Complete set of good ABS sensors and accompaning wiring. I believe these were factory replacements - $80
Premium fuel & ride control rocker switches, the cover plate and antenna switch are gone (switches only) - $5 each
Hood safety latch - $10
Shifter plate w/good rubber - $20
A/C compressor, working - $35
Flywheel shield - $10
Wheel locks w/key - $20
TC spindles - $25
A couple of unrelated fox body pieces - Mustang..........
2 Halo headrests for fox body (perfect cond) - $50
Seat belt buckle, new for '79-'93 Mustang - $15
Oil press sending unit for N/A 2.3 only 100 miles on it - $5
You have any window motors in good condition?
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Do you happen to have a console?
88cat - PM sent.
kashcraft - sorry, console already sold.
You have a PM. :)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Spindles.....are the threads in the caliper bolt holes in good shape?
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Yes, they are.
do you still have the ABS master cylinder, I understand it is in good condition and working?
Quote from: flgypsysoul;383126
Yes I do.  I drove the car before I parted it out.  The brakes worked fine.  No hard pedal.  No trouble lights on in the dash.  Everything is good on this M/C.
Ok I will or may need it also.  I got one but not sure if it will work.  Can you hold off till the 21st on this for me?
Thanks
If I still have it on the 21st, it's yours.
If those spindles are for 11" rotors, ill buy them off you...need them to do my front brake upgrade
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Yes, they are.  That's why I saved 'em!  I used '87 TC spindles to do the front brake upgrade on my Mustang.  11" rotors/73mm calipers.  PM me your address and I'll calculate shipping.
How much for the power door lock panels and overlays shipped to 48858.  Paypal.
Travis
Do you still have the arm rest lights? Thanks.
