Topic: How much would you pay for an MKVII? (Read 6397 times) previous topic - next topic
Reply #45
every stock ford bottom end i've ever touched has had the rods marked
Reply #46
Interesting. Do you guys think this could actually be a 100K engine? The cylinder walls are just too nice. Either way, I'm pretty excited to get this motor in the Thunderbird. Perhaps I'll start a build thread soon.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Reply #47
Yeah, 5.0 engiones last forever and a couple of days if you don't starve 'em of oil or run em hot. Excluding racing, lol.
Hell, my '92 F150 with a 5.0 had close to 300,000 on the engine, ran great till the day she went to car heaven.
Of course, it'd had a new timing set, intake, oil pan, and front cover gaskets, fuel pumps, and some other little piddly mechanical stuff replaced in the 10 years I owned it. Ran great though. If I knew for certain the cylinders weren't egg shaped and past the point of getting by without boring, I'd have kept the bottom end for future use. As it is, I have the previously-mentioned Stanger HO short block on my stand..car allegedly had 60K on it when it was pulled, so we'll see.
So I'd say yes, that engine may have only 100K on it...which isn't very much to worry about it, as long as the thing had proper oil changes and the like. Have someone knowledgeable measure the cylinders with a mic (i know there's a proper name for the tool-can't recall it right this second lol) and that will tell you whether it needs any machining or boring.
The pistons are stockers, as you can no doubt tell from the casting marks, so we know it's a factory bore.
And you also get an HO EEC with the car, lol. It also should have an H pipe like the stangs use, unless you've a better one, or someone has cut the cats from it...if not, might make a few bucks off of the cats to a recycler if you've no use for the H pipe.
If you can still see cross-hatching in the cylinders, it's a pretty good block, at least in the cylinder wall area.
'Luck!
Reply #48
Quote from: softtouch;381012
That is a 1988 VIN number.
A VERY early '88 at that...
In '97 I paid $300 for a rusty '86 LSC and drove it home, that northern stuff doesn't bring much in the south...
Reply #49
Quote from: dragon574444;382380
he numbers in the back of the block are the same as the car's VIN. My dad looked and he couldn't find any marks that say it was bored 30 over, but the rods are stamped with numbers. He says someone was here before, the factory doesn't do that. Could it be a sleeved block? I don't really know what those look like...What do you guys think?
I'm yet to see a original 5.0 that didn't have the rods stamped with the cylinder number...
