Topic: baaaaad gas mileage (Read 3685 times) previous topic - next topic
baaaaad gas mileage
So i am getting between 10-12mpg. I have stock injectors and stock fuel pressure and rarely get into boost. I dont have the EGR hooked up either. I drive up a steep hill everyday for school but i get to coast down it coming back. Ive never heard of a 4 banger getting this bad of gas mileage. My friends 800hp evo gets about that driving in town. Any suggestions?
baaaaad gas mileage
That sucks!  :(
I am going to go ahead and ask the obvious questions.
Have you given it a recent quality tune up?
Is there any other symptoms (any stutters, coughs, hiccups, overheating, etc)?
Are the rear brakes holding?
...and there was light!
baaaaad gas mileage
What are your a/f ratio's like and what tuner?
baaaaad gas mileage
Codes.
baaaaad gas mileage
I gave it a full tune up with the big turbo swap a month ago (besides a fuel filter).
sometimes when i take it out of gear, the RPMs fall to about 500.
My A/R gauge broke so im not sure. Im getting a new put in soon. No tuner yet.
I havent checked the code BUT its been throwing a code after about 20 minutes driving.( ive been super busy with college.)
So im guessing i should get the code checked out first thing huh? and go from there?
baaaaad gas mileage
Well, generally when you want something diagnosed, information relating directly to the cause is the first step. Even if you have to spend 5 minutes at it.
Your check engine light isn't a code, its a hard failure putting the car into limp mode so you can get home.
baaaaad gas mileage
If it started with the big turbo, check to make sure VAM isn't being sucked open.
Also Temp Coolant Sensor and Air Charge Temp sensor can do that stuff.
Get codes :P
baaaaad gas mileage
well when the check engine light is on, it drives just the same when its off. My coolant temp gauge shakes alot from time to time lately. Im taking my car into the shop tomorrow to get the codes. I was thinking my check engine light was on because my EGR isnt hooked up which is setting off my check engine.
everything is Motorcraft except the MSD coil for my tune up.
baaaaad gas mileage
Egr will not cause a check engine light. Let us know when we get codes.
baaaaad gas mileage
That sucks, I thought my ranger was getting bad milage (19 - 20).
baaaaad gas mileage
ALRIGHT i got a few codes!
14- erratic pin signal
23- TPS sensor
25- Knock sensor
34- EGR (took mine off)
41- lean always
65- over changing?
Im thinking the lean and knock is because my big turbo and colder air because of my front mount.
baaaaad gas mileage
14 Pip in the dist bad. This needs fixed. Could be tfi.
23 tps, obviously
25 knock sensor? don't know about these.
34 egr don't worry about this.
41 right side always lean. Generally means bad o2, or injector.
65 overdrive on off not cycled turing test. User error. This doesn't make sense to me. Do you have an electric overdrive onn off switch? If this code was 65 and act is below minimim, that would make a lot more sense.
baaaaad gas mileage
Is the TFI the reason why i have erractic pin signal?
How can i tell if t TPS is bad?
Is the knock sensor ignition timing?
My o2 is brand new so im guessing injector. Would more dense air from the FMIC be doing this though also?
I do not have an over drive switch. Atleast not to my knowledge.
baaaaad gas mileage
TPS, poke a wire with voltmeter (the one that goes 1-5 volts) move throttle to open and closed, if there is a dead spot any where its bad.
baaaaad gas mileage
Get codes.
Also, you said that you swapped turbos.  Since you're running the stock ECU, did you reconnect the orange wire that was originally connected to the old turbo?  It's an O2 ground, and the 2.3T's on stock ECUs will run like ass if it's not connected.
