Topic: baaaaad gas mileage (Read 3861 times) previous topic - next topic
baaaaad gas mileage
Okay thank you soul!
 i have been trying to remember for awhile now to put the orange some where but i also forget! where can i put it? Can i just bolt it down to the engine bay?
baaaaad gas mileage
Goes on the turbo housing, it is the ground for o2.
Bolt that on and it will probably solve your issue.
Great catch by Chuck.
baaaaad gas mileage
There is no where for it to go on my turbo housing though. There arent any bolts on my turbo to bolt it down.
baaaaad gas mileage
There's a place somewhere.  If anything, loosen one of the compressor housing bolts, and attach it there.
Pics of the set-up would help.
baaaaad gas mileage
Okay this is what i did, the wire wasnt long enough to reach to the back of the compressor housing so I took a metal strap and tightened it down pinching the wire to the inlet. I havent driven it yet though. I started Homework instead.
baaaaad gas mileage
Pip erratic signal means the computer isn't always seeing the distributor fire. That is what fires your injectors. It could be your coil, pip inside the dist, or the tfi or associated wiring.
Fix your o2 ground, trouble shoot your tfi, pip and coil. Check voltages, or replace your tps. Double check grounds, and go from there.
baaaaad gas mileage
^ along with the other recomendations i suggest you start saving up and get a wideband o2 and some sort of tuner without them your giving up both performance and milage.
baaaaad gas mileage
Is there anything i need to know before a change the TFI? anything i need to be careful of or to watchout for?
baaaaad gas mileage
Here is a good resource for some of the stuff we are talking about
http://www.turbotbird.com/techinfo/techarticles.html
baaaaad gas mileage
So, did you drive it yet after connecting that orange wire?
baaaaad gas mileage
Thank you soul.
Yes i did drive it and it seems to be running better but it jerks when i drive. There use to be a light tint of blue smoke while i drove it but that went away once i grounded the wire.  havent filled it back up yet though to see the gas milegae. I am putting a new TFI on today to see if that stops the jerking. I also put a new coil on aswell but that didnt help the jerking.
baaaaad gas mileage
I changed the TFI and it is running way more smoothly now. i got the codes erased. im hoping they dont come back! I should be filling up here pretty soon and i'll post how im doing with gas consumption
baaaaad gas mileage
I just filled up and got 24.4 MPG!!! i drive it a steep hill once a day on Monday wednesday friday and on tuesday and thursday i drive up that steep hill 3 times! So 9-10 times a week i drive up a steep hill thats pretty long and i get 24.4 MPG. Im pumped!
