Topic: Post your 2012 Tbird/Cougar TO-DO list (Read 14287 times) previous topic - next topic
Quote from: V8Demon;378321
Paint went down on the body last night and on the bumpers, moulding, and mirrors today.  Body is all wet sanded and polished.  Went with an OEM color from another manufacturer........  Night Hawk Black.  It's a Honda color.
Cool man.  Post up some pics when finished.
1. Order a SHLOAD of parts
2. Install and plumb fuel cell
3. Run and install battery reloaction
4. Install TC springs and shocks
5. Install tranny xmember
6. Install driveshaft and new pinion seal.
7 Install a bunch of other stuff I cant remember.
Being as my car is a rolling shell, mine is more a novel than a list, but a few things that come to mind
1. Finish body work and get everything at least in primer (may stay that way for a while, I love the primer look)
2. SFC's (wasn't high up on my list til I joined this forum)
3. rebuild/upgrade front and rear suspension
4. Battery to trunk
5. 5 lug swap so I can put some decent brakes on it (stock are barely adequate for a bicycle)
6. add a couple hundred horsies to the wheezing 130hp 302 (maybe 351 in future, still not sure yet)
7. full gauges
8. maybe a t5
9. trak-lok and something lower than 2.73's
10. stumble upon large amount of money to make the above list happen (I do accept donations :D )
Looks like there are lots of ambitious plans for 2012!  Hope the car gods are with you guys.
I've located an A4 block and forged rotating assembly.  A set of ported 192 Canfields (finally got them back after two years...), Kooks headers, RPM II intake and a 1 inch bigger crank pulley on the blower, plus some supporting equipment.
Got to be done, tuned and sorted by June 1st for the HRPT.
Quote from: 86T-bird;378441
VERY NICE!  Gonna do any dyno runs?  lol.
I'm gonna finish my 5 speed swap. I bought a T5 along with the pedal assembly and the bell housing, but I never got around to getting the rest.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Quote from: 50tbrd88;378497
On the Tour?  If its sorted out, sure!
I've drag raced and auto crossed at other HRPT's.  Just depends on the events at the venues I've attended (and if I got there in time!).  They're usually a riot to watch and partite in.
You were running a "XXX" roller block before?
Quote from: thunderjet302;378540
Oh yeah.  The old line: "never enough money or time to do it right the first time, but always money and time to do it again" rings pretty true when pushing an xxx block...
Reply #39
Quote from: DVP;378283
Well to start Im pulling it out of storage and getting it tagged.
Now if i can keep my automotive-ADD under control here is my current plans.
  • 351- GT40 (Non P) heads, Cam & Intake (TBD)
  • MAF conversion
  • Equal Length Shorties
  • Possible C-4 swap. Trying to figure out if I can make an AOD hold for as cheap as I can swap a decent C-4 in.
  • New lers, HATE Flowmasters, Possible side exit out 1/4 panel
  • 5 lug swap
  • 17" wheels- Stock Mustang is some form
  • 8.8" swap when the 7.5" goes BOOM
  • SFC, possibly jack rails
  • Put interior back together
  • Replace bumper skin with TC skin
  • Swap hoods
  • New shocks, Possibly struts
  • New springs
  • 13" Cobras - If things go right
Im ready to throw some money at this car. Id like to get it moving under some decent power, then start dealing with body issues. Im shooting for 350/350 but all i want is 300s.
Honestly if I can get the suspension semi sorted out (wheel/brakes included) it will be a more successful year than the last 2 or 3
Reply #40
Get car tuned correctly (Mass-flo isn't a plug and play solution and tech support and me haven't seen eye to eye)
Move ratchet shifter back from stock location, remove arm rest and fab seat + mirror switches into cover for ratchet shifter
Fix c4 leak, not sure where it is coming from but if it sets any at all it needs a couple quarts to motivate it. May switch to AOD and put some DD miles on it
Drive car
Reply #41
Quote from: Soul;378999
Drive car
There's the bottom  line!
Reply #42
  • MAF conversion
  • 5 lug swap
  • Swap hoods
  • New springs
Dillion, it's time for the resurection?
Reply #43
Ya its been sitting for couple months after Fuel Injection upgrade, I'm too far from it and no time off.
Reply #44
- CHE rear control arms
- 8.8 rear end with disc brakes (if i can find one)
- 11" front brake upgrade with continental calipers and stainless steel brake hoses
- Repair trunk panels
- Install an amp for the cabin speakers
- Paint/POR the entire inside of the trunk (provided somebody helps me to patch the holes rotted in the trunk)
- Eibach sway bars
- 5.0 HO with 347 stroker upgrade (if i have the cash to finish the build)
- Aluminum driveshaft (if I can figure out where to get one made/modified)
- clean the headlights, take those reflector things of the taillights to make them clearer/nicer
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
