Topic: Post your 2012 Tbird/Cougar TO-DO list (Read 14212 times) previous topic - next topic
1) Acquire funds.
2) Purchase Tbird.
3) Make new list.
1. finish wheel swap
2. remove wheel swap, engine, and interior
3. take shell to body main for paint
4. reverse steps
1988 T-Bird LX- Awaiting HO build, Monster "Eat My Shift" AOD rated 550Hp. BBK ceramic shorties, Jegs mustang (catless) H-Pipe. mustang catback modified axle back for tbird, 94 17" Cobra wheels, 98 'Stang GT 8.8 Traction-lock
Hmmmm, more of what I hope to get done than a to do list:
1. Swap in a T3 turbo instead of the IHI
2.FMIC
3.Get the moonroof fixed and replace the seal
4.Atleast start the body work and if I get it finished atleast a temp coat of paint
5.Get the leather seats recovered and possibly install heaters in them
6.Get the speedo reading right, weather that be a speedo gear change or putting the proper gears on the rear(it was an auto, so it has 3.73 gears
7. If I get all that done Ill need a new list!!
to do list for 2012? well....
...definitely-must-do list:
- Tag
- Tires
- Struts/shocks
- Brakes
- clean headlights again
- get that GD torx bolt out of my back seat floor pan
...hopefully-will-get-to-do list:
- split-port heads and MAF ECU
- TC rear
- seats and door panels
- dash cap
- dash speakers
- guage set
...of course there's LOTS more to be done, but that's all I hope to be done with this year. And if I can get all that accomplished this year I will be VERY happy:) Although I doubt I will accomplish half of it... oh well we'll see:cool:
Quote from: Ether947;377897
1) Acquire funds.
2) Purchase Tbird.
3) Make new list.
Ditto. Except I'm thinking tax time and a cougar.
Already started in December of 2011:
1. Remove sub box, amp tray, all trunk trim and carpeting to store in the house.
2. Remove previous head unit, amp power wiring and rca cables.
3. Remove rear bottom seat cushion, front sill plates and under dash trim.
4. Remove dash bezels, speaker grills, vents, etc from dashboard.
5. Unbolt tachometer from dash
To do in 2012:
1. Run 4 gauge power cable from engine compartment to trunk
2. Make new positive/battery to solenoid cable to install Tsunami battery terminal
3. Big 3 upgrade
4. Figure out negative cable and install negative Tsunami terminal
5. Find a nice ground in trunk for amp ground cable
6. Headlamp relay upgrade
7. Bypass system sentry for "headlamp out" indicators or somehow find a way for it to work with relay upgrade
8. Install new headunit
9. Wire in 12volt charging unit somewhere in drivers vicinity
10. Spray undercoating/sound deadener on backside of trunk trim pieces to sturdy them up
11. Install unbroken fuel door release with cord
12. Redesign amp tray
13. Reinstall trunk carpet after vacuuming
14. Setup remaining stereo system
15. Fix/fabricate rusted out ler hangers
16. Change oil, new drain plug gaskets
17. Turbocoupe spindles,backing plates,bearings,calipers,rotors, Moog balljoints, new outer tie rods (check inners)
18. New chrome Gorilla lug nuts with locks for the basketweaves
19. Paint calipers red before installing
20. Flush brakelines and install braided stainless steel brake lines on front
21. Valve cover gaskets and ARP stud set
PLANS FOR FUTURE
1. 3.73 or 3.55 gear change
2. Battery relocation to trunk
3. Tint windows
4. Explorer or Cobra upper and lower intake
5. 5 speed swap
6. Subframe connectors
7. Fuel pump door in trunk floor
8. Larger fuel pump
9. Body work and repaint Oxford White
10. Get basketweaves refinished
11. Reupholster seats
12. New 245/50/16 tires
Of course, winning the lottery would help!!
I thought I had a big to do list.
Five lug and cobra brake swap
Drive shaft loop
255 lph pump
CHE control arms
finish moulding on drivers side
front and back window trim
headlight relay kit from RJM
Positive stop shifter
change intake to something better and still close hood
Too much to list...
Try not to cry when I see her around town, rusting away :(  I want her back.
Hmmm..
Put it back together after it gets painted next week - FINALLY ( you have NO idea the odyssey I've been through with this car).
Blow up motor with a very low12/high 11 second pass
Replace with single turbo 408.
hmm.. to do lists..
blue TC - install SFCs, new stainless DP, coilovers for the front and a dynotune.. then 6pt cage and make some passes at the track.. i predict low 10's with it's current setup
black TC - pull all drivetrain, rip out all suspension, gut EVERYTHING, cut the front end off(everything from the firewall, forward) and front subframe, build full tubular frame with integrated cage, spooled/narrowed 9" with 3.54's, 4 link, mustang 2 tubular control arms with cobra spindles, cobra brakes all around, rebuild my recent 408 score, aftermarket clevland heads, big garrett or precision, MS2.. hopeing to see 8's with this 1.. pure race car, trailer queen!
white TC - make it roadworthy, repair front clip rust using pieces cut off the black car, T3/T4, Tial wastegate, Greddy bov, custom header, custom intake, boport 1.9 cam, port and rebuild or replace head with bigger valves, build custom stainless exhaust(building everything myself, from the downpipe to the tailpipes), get it tuned and drive the piss out of it
capri - drive to the track, run low 9's, drive home from the track
Quote from: V8Demon;378197
Hmmm..
Still not painted yet?  Seems like forever ago when you had started a thread about your car getting painted.
I also have a mildly new plan of attack for the engine and maybe some external front end mods. That is all I'm saying.
Well to start Im pulling it out of storage and getting it tagged.
Now if i can keep my automotive-ADD under control here is my current plans.
  • 351- GT40 (Non P) heads, Cam & Intake (TBD)
  • MAF conversion
  • Equal Length Shorties
  • Possible C-4 swap. Trying to figure out if I can make an AOD hold for as cheap as I can swap a decent C-4 in.
  • New lers, HATE Flowmasters, Possible side exit out 1/4 panel
  • 5 lug swap
  • 17" wheels- Stock Mustang is some form
  • 8.8" swap when the 7.5" goes BOOM
  • SFC, possibly jack rails
  • Put interior back together
  • Replace bumper skin with TC skin
  • Swap hoods
  • New shocks, Possibly struts
  • New springs
  • 13" Cobras - If things go right
Im ready to throw some money at this car. Id like to get it moving under some decent power, then start dealing with body issues. Im shooting for 350/350 but all i want is 300s.
Quote from: 50tbrd88;378227
Paint went down on the body last night and on the bumpers, moulding, and mirrors today.  Body is all wet sanded and polished.  Went with an OEM color from another manufacturer........  Night Hawk Black.  It's a Honda color.
