Topic: Post your 2012 Tbird/Cougar TO-DO list (Read 14223 times) previous topic - next topic
Reply #60
Hoping to get all this done.
1. Paint engine bay (will do shortly)
2. Raptorize underside (done)
3. Sound deaden inside (done)
4. Re-install front and rear suspension.
5. Aquire/Install stang dash
6. Finish subtle little body mods
7. Get body shell and other panels into color
8. ??????
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #61
After this roadtrip it needs
Exhaust
Oil pan resealed (might replace the motor while I'm at it)
Replace window motors
Replace heater core
Reply #62
Quote from: bryan163;384196
I banged out my list. 03 control arms, 93 mustang brakes and tc hood are all done. Just driving and enjoying now.
Are those flat or matte black hood scoops I see? I was thinking of doing the same with mine. The whole car looks fantastic. I really like what you've done.
[SIGPIC][/SIGPIC]      STEVE ;)
Reply #63
Rebuild the 3.8 V6 in my cougar because it needs new rod bearings.
Reply #64
1. Finish/ fab a new forward center console with drink holders around the 4R70W mustang shifter
2. Pull and paint the side moldings in body color
3. Yank valve covers to install new breather setup
4. Install headlight relays
5. Dyno!
6. Finish A/C (make new hoses and charge)
for future:
Buy MS2 daughtercard and fab in a GM stepper for idle control
Reply #65
Updated above list 4/30 :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Reply #66
Updated list today :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Reply #67
I'm gonna add one to my list too:  install new coil, plugs, wires, cap/rotor before power tour.
Reply #68
for this summer i only finish what i've started
-wait for my che control arm  and bolt it on
-order diff bushing
-put my tc rear
-fix the floor,seat rails,make sfc
-reinstall bucket seats
-plug my prop valve
-get e-brake cables
-make space on e-bay
-remove egr and clim
-e-fan with thermo switch,relay....
-remove dust of my shorties with dual who was in the attic and swap it in with lock bolts
-go to alignement
-clutch job on diff
-draw on the road with my old rear tires
-install my potenza
-pray for the summer not ending after all those mod
