Topic: Sandblasting (Read 2092 times) previous topic - next topic
Sandblasting
I'm looking into to doing some sandblasting this year;
I would probably be starting on some aluminum heads and intake in an enclosure of some sort, But the big project would be an 8.8 rear out in the open.
My big concern is safety for myself, I don't want to give myself silicosis or anything like that... I would like max protection within my budget.
I definitely don't have the funds for a "Fresh air supplied" Helmet and Pump, But I do have access to Oxygen Tanks and Medical Oxygen Hoses and what not...
What do you guys suggest I use? Or what Do you guys use?
I was looking at this combo of items on the Home Depot website:
http://www.homedepot.com/h_d1/N-5yc1v/R-202714568/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
http://www.homedepot.com/h_d1/N-5yc1v/R-202714579/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
http://www.homedepot.com/h_d1/N-5yc1v/R-202714636/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
http://www.homedepot.com/h_d1/N-5yc1v/R-202714577/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
With this setup, I think the Window on the hood would degrade too quickly and not be changeable~Unless I could come up with some sort of film to put over it?...
And would the filter really be enough for heavy sandblasting in the open?
Thoughts?
Sandblasting
I also have the option to buy this right now, But it just doesnt look very efficient at all... Even though it has an Air Inlet at the back and replaceable windows, I would still need a Respirator:
Sandblasting
I never used sand, so not sure what to tell you as far as safety.
Sandblasting
As far as safety that all depends on the person. Ive normally just used a respirator that covers my face.
On the sandblasting Ive also been told not to sandblast heads.
Sandblasting
Oh!,
I actually mean general abrasive blasting, But I would like full protection for up to the harshest media I used.
On the heads I was actually gonna try "Soda Blasting" after reading up on it a bit.
And I'm pretty sure this is the same method my local old school machine shop used to clean up the aluminum intake on our Astro Van since he said he couldn't tank it.
Sandblasting
Ah ok, ya sand in an engine, you can guess how that would end up!! LOL
Ive seen the soda blasting used on the history channel on an old thin piece of aluminum. Worked great.
Sandblasting
sand and aluminum heads = big no no! unless you're not touching the gasket surfaces, it will disfigure the hell out of them, as sand will take away some of the metal.. i've actually used my sand blaster to cheat doing port work lol
but that hood you posted a picture of, those things are great.. i have 1 that's similar and use it all the time.. i just use those cheap, disposable respirators under it, as not much dust comes up inside the hood.. other than that, i just wear a welding jacket and welding gloves
Sandblasting
A hood with a respirator and shorts with a tank top. It will feel so good when you stop. :)
Sandblasting
Quote from: HAVI;376854
http://www.turbineproducts.com/fresh-air-respirators.html  I've been pondering buying this.  When I get my full blasting set up finished, and start doing work for others, hopefully it will pay for itself in time.
those things get hot after about 40 minutes of continuous use :mad: i used 1 when i was cleaning cartridges for a company called spartan air purification.. you'd be better off with an air compressor supplying your breathing air, although it may smell a bit funky.. lol
Sandblasting
Quote from: Shadow;376873
shouldn't use an air compressor... you will get oil and other hazardous stuff in your breathing air. there are other companies that make air supplied hoods and masks.
Sandblasting
it was a bit of a joke, but there are filters and water/oil traps you can use.. if i was to ever seriously use a compressor, i'd use my little harbor freight oil-less pancake
Sandblasting
Quote from: Romeo2k;376806
I went ahead and bought this for $20 shipped to try and use with a 3m or sundstrom respirator.
It arrived today and seems to be ALOT older than I was thinking, The inside head "snugger" has dry rotted free from the metal shell, But I have an idea to use the liner out of a bicycle helmet. Visibility is excellent (other than it could use new glass pieces) which I was really unsure about with that middle separator, and it has an air inlet on the top.
A few minor mods and it should last many more decades and serve pretty well.
I dragged my Dad over to Home Depot (Military Discount ;-) ) with intent to purchase a Sundstrom Half Mask Setup, But apparently they dont carry them in store. :punchballs:
Sandblasting
We
