Topic: Explorer 302 (Read 6314 times) previous topic - next topic
Explorer 302
So does the 302 in the Explorer have an actual GT-40 intake or is it a modified version? What about the heads, are they a GT-40 or something similar? I'm guessint they flow better then my stock heads on the 88 302.
Explorer 302
the search will pull up a lot of info on both
Explorer 302
I just got a 98 Explorer motor and it has the gt40P heads.
Explorer 302
don't know why i didn't see this before.. guess i'm not the only 1 who missed it lol
the heads are GT40P's on 90% of explorer motors.. some of the early 5.0 explorers had the regular GT40's I THINK.. the GT40P's are 1 of the best heads you can get for a windsor motor.. the intake ISN'T a GT40, but it does flow better than what you currently have on your car..
i don't know what's currently done to your motor, whether it's an SO or HO, etc etc.. but whatever it is, if the top end is stock, the explorer setup is better.. if you have an HO, it'll go on without an issue.. if it's SO, you've got some decision making to do, because the GT40P valves are larger and will make contact with your pistons.. you have a few options to make it work, but i'd suggest either a rebuild with new pistons OR a healthy HO shortblock
Explorer 302
Or, its more like the ptv clearance is almost identical between the h.o. and s.o. bottom end, and if you can run the s.o. pistons, you won't need a new motor or bottom end, and you'll have slightly higher compression, giving you more power. A h.o. cam and s.o. pistons with gt40 heads, should clear, but always check you ptv.
Explorer 302
i give up lol.. everyone says different bs about the PTV clearance.. i don't personally know from experience, because SO pistons are trashcan material to me
Explorer 302
You will not have any piston to valve problems with the SO piston IF you're running the stock SO or HO cam. The HO cam has only .440" lift. I wouldn't run the SO pistons with any after market cam because even if you keep the lift low it can still hit if the duration is high enough. You can safely run .500" lift with HO piston IF you keep the duration under 220* at .050". Millions of mustang guys run "E" cams with stock pistons with no issues. The "E" cam has .498" lift and 220* duration at .050". If you have the whole explorer engine just put a HO cam in it and swap the engine, problem solved, no PTV issues.
Explorer 302
Lots of guys here run the e camand gt40's without ptv on a stock bottom end. I just don't get what all the hate is against the stock s.o. pistons. I have seen many over the years take nitrous till the block split, endure superchargers and rpm's. What makes them so cruddy stock?
Explorer 302
Careful everyone, be mindful of the geometry of camshafts....LIFT does not a good or bad PTV clearance make ;) the entire profile really needs to be known among other things if you want to somehow *calculate* it or do some hand-waving.
I had hoped for this as well for the red cougar's engine. Turned out with the H.O. cam and GT40 non-P, F3ZE heads, S.O. bottom end, there is NOT enough clearance. The bigger valves I determined to be the sole cause of this, but my comment about cam designs still stands.
DONT DESPAIR though....I have to go now but I will link to my build thread where I show you how to easily flycut your S.O.'s so everything will fit, with a valve, a power drill, and sticky sandpaper. If you want to dig yourself it's in here somewhere. Also search google for a thread on http://www.ls1tech.com, that's where I found it.
Explorer 302
they're cast junk.. they've been trashcan material since i had my first bird and i found the edge of the decks were brital, chewed to hell and starting to break away.. i've only used stock HO pistons twice, everything else has been aftermarket
Explorer 302
Quote from: ZondaC12;377411
here it 'tis..
http://www.google.com/url?sa=t&rct=j&q=flycutting%20pistons&source=web&cd=1&ved=0CCEQFjAA&url=http%3A%2F%2Fls1tech.com%2Fforums%2Fgeneration-iii-internal-engine%2F709183-how-flycut-pistons.html&ei=zMUMT-6xDsKtsQLVo-WMBg&usg=AFQjCNF_m-nki9BFuZDDrfoeSg456l9cUA&cad=rja
Explorer 302
Yup tharr she blows!!!  Really good write-up, follow it to the letter and you'll be mint. Tedious? Yes a bit...my arms were about useless after lifting the heads on and off about 2000 times LOL. But so worth it. And if you just make 'em look like what you see on H.O.pistons, go about 1/4" deep, not like you'll lose enough compression to piss you off, and using a valve that is just slightly bigger than the one that has to go there....you've got it made.
I was soooooo pumped to know that I could keep the entire original bottom end. Hehe.
Explorer 302
for SBF guys using any type of GT40 head, it's been recommended to use chevy valves to do the fly cuts
Explorer 302
I just picked up a set of gt40p heads and explorer intake for mine. When I saw this post I was hoping to read they would work without cutting the pistons. lol
Explorer 302
They will with the stock cam. But you'll need GT40P headers. The plugs dont fit the exhaust manifold with the P heads. I was going to run a set of P heads on my engine but the stock manifold would'nt clear and I didnt have money for headers so I used E7s. I have a set of GT40P heads and headers I just bought last payday that will recieve big valves and screw in studs.
