Topic: Explorer 302 (Read 6316 times) previous topic - next topic
Explorer 302
Quote from: Shadow;377432
for SBF guys using any type of GT40 head, it's been recommended to use chevy valves to do the fly cuts
Tad bigger than the GT40 exhaust valve, which is of course bigger than the intake...so all your bases are covered and then some.
Explorer 302
that's why they say to use GM valves.. lol of course valves from a specific head, but i forget what head/year exactly.. never put much thought into it, since i don't deal with the SO pistons
Explorer 302
Quote from: Bruce M;377575
They will with the stock cam. But you'll need GT40P headers. The plugs fit the exhaust manifold with the P heads. I was going to run a set of P heads on my engine but the stock manifold would'nt clear and I didnt have money for headers so I used E7s. I have a set of GT40P heads and headers I just bought last payday that will recieve big valves and screw in studs.
The need for special headers is a myth. All you need are 90 degree plug boots and you're golden. I have the P engine, and BBK headers. Instead of spending funds on different headers, I bought new plug wires with 90 degree boots and never looked back. No burnt wires either.
Explorer 302
The plugs are close though still right? As in, no taking plugs out without removing the headers first? Granted in this day plugs ought to last you 100k.
Explorer 302
I can swap my plugs with the headers in place.
Explorer 302
vinnie, there are some headers that do interfere with the plugs, yours aren't 1 of them.. stock 5.0 stang headers WILL NOT work, as the primary tubes run directly into the plug's 'area'.. so you're right in saying it's false, but there's a bit of truth behind it, as some headers will interfere
Explorer 302
Ahhh yea see I would cheap out and find stock stang shorties :hick: lol. But at least widely available ones like BBK's are good, not like there's ONE brand/style of header and you have to hunt it down.
Explorer 302
BBK and Ford Racing headers are the only ones that I know of that fit P heads.
Explorer 302
Quote from: ZondaC12;377645
  lol Thats what I am running now. Stock mustang shorties.
Explorer 302
Hi, its been awhile since I've been on this forum. Nice to see its still here! So from this thread I take it that GT40P's will not work with stock SO pistons, Stock HO cam and 1.6's without valve reliefs. That sucks as I just pulled a set from the local yard. Likewise the stock mustang HO headers wont work either? Thought I saw a set work as I was googling. Oh well. I'm a little concerned about grinding valve reliefs in the stock SO pistons as the top faces don't seem very thick when compared to the 86 flat tops (with reliefs) I have in my mustang. How deep can be cut?
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
Explorer 302
Everyone should read through all of this........
http://forums.corral.net/forums/5-0-5-8-engine-tech/1014187-anything-everything-gt40p.html
