Topic: Blown turbo (Read 969 times) previous topic - next topic
Blown turbo
I have a Garrett Airesearch T3 turbo with .63 exhaust. It doesnt have shaft play at all but it is leaking oil out of the exhaust side. What rebuild kit should i buy for the turbo?
Blown turbo
it says M11 in the compressor side and M4 .63 on the exhaust side. Is that what i need?
Blown turbo
There should be a tag on the compressor backing plate. Use the numbers off that to order a kit from a reliable vendor, such as g-pop shop, or turbocity.
