Topic: gear ratio (Read 7654 times) previous topic - next topic
gear ratio
Which would be a better gear ratios for my 88 cougar v6. 3.73 or 4.10? Im looking for better acceleration and and bit more too speed
gear ratio
You will lose more top end speed the higher the gear you use. You really won't gain a lot with a stock v6 to make a big impact. That 88 six is an oddball with that balance shaft.
gear ratio
As of now im planning a stroker rebuild for my 6 to add a lil more power. But do you have any suggestion on a higher top speed
gear ratio
Put a 199 mph spedo in it.
gear ratio
Swap in a sc motor, or get a v-8 in there. No offense to the v-6, but you go broke trying to make it fast, without using a completely different engine and parts.
gear ratio
I would go with 3.73s, you might not gain any top speed but you will get there a whole lot quicker. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
gear ratio
I a
gear ratio
I figured he is stuck on 85 mph. If he does the 199mph he might be happy!, he really didn't come back with any more info!
gear ratio
It is possible to actually gain top speed with steeper gears.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
gear ratio
Quote from: Dan B.;370668
Agreed though usually not a lot, will always be lower HP engine... If the engine isn't deep enough into it's HP/torque curve to overcome wind resistance, increasing the revs may eek out a bit more speed...
gear ratio
I think it would a pretty big difference putting 3.73s over the factory 2.73 or whatever the stock 7.5 rear comes with. After I did my 347 stroker with C3 into my 87 tbird I got pretty tired of hitting top speed and having everyone (including a smart car once!) blow by me on the highway. Deeper gears are fun, but it gets tiring in a hurry doing 4500 rpm going 70 miles per hour.
gear ratio
Or you could run an overdrive transmission, like the 88 v-6 is stock. Your top speed is not going to change on an 88 v-6. Not higher anyways.
gear ratio
I think its 3.08 ill be certain in the morning when i can look at the certification plate on my car
gear ratio
Ive thought of using the motor from a cougar/tb supercharged but finding one is no easy task
gear ratio
Engine upgrade is your best bet. You may not like the idea, but 5.0s are easy to find and easy to fix. Might be affordable if you find the right donor car for the PCM and harness.
