Topic: gear ratio (Read 7669 times) previous topic - next topic
gear ratio
lets say your stock gears are 3.08's.. the purpose of switching to 3.73's or 4.10's is acceleration gain, not top speed gain.. can you gain more top speed? it's possible, but it depends on the cirspoogestances.. cirspoogestances a stock 3.8 doesn't have.. the 4.3 stroker kits are built for SC's, as are most other aftermarket parts.. so keep that in mind before spending any money on your motor
gear ratio
Quote from: Jmoore87;370897
Ive thought of using the motor from a cougar/tb supercharged but finding one is no easy task
best place to find 1 is SCCOA.. super coupe club of america.. they have a classifieds section on their forum.. the BEST way to do it is with a megasquirt DIY ecu, if you know what you're doing. the SC harness is super complex and has a lot of other  tied into it
gear ratio
Stroking it will indeed cause U to gain top speed, but that is a total rebuild. A lot of money for not a hole lot of gain. If you have a supercharger laying around go for it. Just swapping for a supercharged engine or 5.0 will give U what U want. Could adding just a supercharger be an option?
gear ratio
not recommended.. NA 3.8's have py pistons.. they'll start getting weak at 8psi, busted at 10.. an SC bottom end would basically be a must.. SC blocks are stronger too
gear ratio
Good 2 know. Let's avoid that! Had 2 ask.
gear ratio
did a bunch of research on the subject when i had my SC and wanted to build a 2nd motor :p lol
gear ratio
Im not looking to go crazy on top speed. Maybe up to 120 mph. I just dont want to stay at 85 untill i can dind a different engine. If im not mistaken i have 3.08 gear ratio
gear ratio
Understood. However, gear ratio is gear ratio. Look at it like a transmission. You can go faster in 2nd or 3rd gear than you would in first right? The rear gear changes you are asking about will most likely hurt top speed instead of help. Deeper gears are for acceleration, not top speed.
gear ratio
i don't think a  stock NA 3.8 is capable of hitting 120 lol
gear ratio
Have you just been hitting the speedo limit? Have you done the j-2 mod?
Where are you driving 120mph legally?
gear ratio
Yes ive taken my car to its limits several times mainly on the highway. And it takes no time to get her to about 90mph. Whats the j-2 mod? And i dont have anywhere to speed legally. One reason i want more on the top end is because i was hauling ass down the highway one night with a vw beatle and the the  thing pulled away from me at the top end and all i could do is watch it walk away lol. Hurt my pride lol. Theres a 98 gt engine i can get my hands on but it doesnt have the wire harness.
gear ratio
I knew these speeds were not happening legally. A big majority of us on this site break the law by driving our cars with missing, altered, or disabled emission control devices. No judgement here. The j-2 mod is so digital speedos can read more than 85. Can anyone answer me why this car is so slow on the top end? I had a 93 Cougar with a 3.8 that would do 115. Rear gear on that car was factory, and I believe it was 3.08. It would hurt my pride to be competing with a Beetle at all! lol
gear ratio
She is completly stock at the moment except for for the intake. And I was fine against that  bug untill i got to 90. Yea it still hurts lol. This is why i want more on the top
gear ratio
Well, the 93 cougar would have basically the same engine, basically the same rear gear, and weigh a lot more weight, so it should be slower.
gear ratio
tisk tisk.. speeding.. you should be ashamed LOL and emissions controls? what the  are they?!
