Topic: upgraded suspension? (Read 2213 times) previous topic - next topic
Ive been looking around for new tubular A-arms, a tubular K member and better springs but i cant find any... Ive found alot of mustang stuff so i was wondering if foxbody parts like the ones i just listed would would for my car? Also id really like a got a tubular engine brace as well. Any tips or help would be appreciated! thank you
Go to Cool Cats and read their section, outlines what you can use and what you can't.
http://www.coolcats.net/modifying/index.html#suspension
thank you soul
Alright, so I can use any SN95 tubular A arms. I found out that I'd have to custom fab my own engine bay brace. I can buy a set of rear control arms from CHE. While poking around I got curious about a 2 point G-load brace, upgraded torque boxes and a panhard bar. Unfortunately I realized it was talking about for V8 and V6 cougars. Nor did I find anything about a tubular K-member for a turbo coupe. Does anybody know if I could use these parts or will it not work on my car?
If you mean by engine bay brace, strut tower brace, it will line up fine. I would recommend caster camber plates from maximum motorsports if you are going all out.
Torque boxes are the same. K-member for a 87-93 mustang should work, but you will need to add spacers or slot holes to make it all line up right.
Panhand bars are basically a custom setup anyway you look at it. Any parts there will take modifications.
What year mustang should i get the Strut tower brace from? thank you for your help
I am not up on the 2.3 motors. I know the 5.0 one will fit, but not sure. Goto nato or turboford and see what they are running.
[url
Wow Tom, that alot of use full information! I unfortunately I don't have the tools to weld nor does anybody I know. Nor the tools to make templates.
It is
Tom.....from whatI understand, you make a large plate that extends from the caster/camber plate all the way down the tower to below the frame rail?  You have any pics of this?
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
