Topic: 87 or 88 t-bird in the junk yard!!!!!! (Read 1942 times) previous topic - next topic
let me know if you need any parts
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Is that a Mark VII directly behind it ?
Driver side outer signal light for me if it's in good shape.
Quote from: hypostang;366433
yep!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
3.8 car?
yes
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
how are those cornering lamps?
cloudy
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I am in need of a head light switch.
how is the driver's headlight? cloudy/yellow or in semi ok shape?
Pretty cloudy
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
sigh they all are haha.. kinda make me want to switch over to a 83-86 header panel
Quote from: daminc;366457
Do you need the ones for the fenders? I have a set on page 7 of my ad.
Does it have the metal or plastic trim on the rear window? Thanks.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
that i do not know, i am going to get some parts from it tomorrow
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
