Topic: 87 or 88 t-bird in the junk yard!!!!!! (Read 1628 times) previous topic - next topic
Check that driver side signal light. If it's pretty nice, (I don't expect perfect), I'll take it as long as it's not cracked or spider webbed.
fender or headlight
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
The signal light mounted right next to the driver side headlight with the orange reflector. Thanks.
Quote from: vinnietbird;366965
its junk crack on the bottom corner
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 347Thunder;367140
Thanks for trying, I appreciate that.
