Topic: Lower rear DS 1/4.... (Read 3250 times) previous topic - next topic
I need the driver side rear 1/4 panel. Just the "skin" not the whole structure behind it. From the middle of the body trim to the bottom of the panel.
Everything okay with the sport!?
The 1/4's both had some damage when I got it. I'd like to do a little work to the driver side before paint. The Sport was beat really badly when I got her. 2 more days and the crusher would've been it's demise. I got there just in time.
Try this: http://www.car-part.com .
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
Quote from: RoyLPita;365698
The cheapest was $150.00.......no way. I'll find one eventually here on the forum or at a yard. I'm not spending that kind of money when I basically need a skin.
Quote from: vinnietbird;365655
Oh, okay. I'll take pictures of what is on my parts car, if you can use them, I'll cut them off.
On a side note, didn't you have the car painted not that long ago?
THANKS !!! Yes, I had it painted 2 1/2 years ago. never meant to be THE paint job. Just something to prety up so the wife wasn't embarrassed.LOL. I appreciate you.
Quote from: vinnietbird;365705
How about http://www.junkyarddog.com? It couldn't hurt to check there, too.
2003 Marauder 300B
Up to the top........
I wish I could. No vacation time til November, and even then, no way to transport a car. My luck.
how much do you need, picture
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I have one in my junk yard, I will have to check to see if its good, but shipping it 3,000 miles might cost you if it's too big
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
What I need is small. Just the lower 1/4 panel. MAYBE 10 or 11 inches high and from the wheel well to the bumper. I don't need all the structure behind it. Mostly the outer skin.
i'll go check tomorrow can you shoot a picturewith the cut out you want, I will have the sawzall in hand:mullet:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
